Looking for Analog CDI to ARINC converter
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
recapen(at)earthlink.net
PostPosted: Sun Aug 16, 2020 1:00 pm    Post subject: Looking for Analog CDI to ARINC converter Reply with quote
OK tron-heads,
The 430W will output both Analog CDI and ARINC 429 signal sets…simultaneously.
The SL-30 will output Analog CDI signals - or - ARINC 429 signals – mutually exclusive…no ‘both’ setting.
I have a GRT Mini-AP with their ARINC interface as my primary HSI interface. Works fine when the SL-30 is in the ARINC mode…I can select either the 430W or SL-30.
I also have a NARCO NAV122D/GPS as a backup NAV radio – it has a display head which will accept the analog inputs from the 430W and the SL-30 (when in the Resolver/converter mode). The NARCO is set up as a backup display only.
If I had a converter, I could set the SL-30 to converter mode and drive both the NARCO and GRT displays when necessary.
Anyone know of anyone that makes such a box or card…?!
Ralph Capen
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
