Omerrett
Posted: Wed Jul 29, 2020 12:27 pm Post subject: Landing on grass |
I’m considering the purchase of a kis tr-1 (current owner says it has the heavy duty nose gear).
2 questions, is there such a thing as heavy duty nose gear for the tr-1?
Also is the plane grass field (relatively smooth) capable?
| | - The Matronics KIS-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Keith.Miller(at)esa.int Guest
Posted: Wed Aug 05, 2020 3:39 am Post subject: Landing on grass |
Oliver
The TR1 has gone though quite a few variations on the nose gear ( at least 3 different types , plus some additional strengthening of the 2nd version ) , some were good , some less so . if possible sent a picture of which nose gear is installed ( or provide a good description of it)
- original gear ( sprung steel with no springs or pivot ) ,
- mk 2 gear : large spring and pivot point with a streamline profile steel main leg.
- Mk 2 gear with additional stengthening - as Mk2 but with two steel strenthening bars welded down the full length of the main leg
- Mk 3 gear large spring and pivot point with heavy duty thick wall round tube for the main leg
So the answer is yes they do exist and if you tell me which one I can explain what to look for
I operate my TR1 regularly on both hard and grass runways. Some grass not smooth at all, I have had no problems for 17 years with the Mk 3 nosegear which is extremely strong - but a lot heavier .
Keith
650 Hours total time on my Tr1
[img]cid:1__=4EBB0F2ADFBDB3978f9e8a93df938690(at)esa.int[/img]"Omerrett" ---29/07/2020 22:29:27-----> KIS-List message posted by: "Omerrett" <olivervandam(at)mac.com> I’m considering the purchase of
To: kis-list(at)matronics.com
Date: 29/07/2020 22:29
Subject: KIS-List: Landing on grass
Sent by: owner-kis-list-server(at)matronics.com
http://forums.matronics.com/viewtopic.php?p=497475#497475
105 Bytes |
5411 Time(s) |
