Foamy oil leak
PostPosted: Sun Jul 26, 2020 6:24 am    Post subject: Foamy oil leak Reply with quote
Noticed an oil leak on the right side of the carburetor after a flight yesterday. It was pretty hot outside and also did a few gyro maneuvers. The oil temp was at 72 briefly, then mostly 65.
Any ideas?
Thanks.
 Filesize:  271.92 KB
 Viewed:  4581 Time(s)
easy_driver
PostPosted: Mon Jul 27, 2020 1:47 pm    Post subject: Re: Foamy oil leak Reply with quote
oil sucked into the supercharger and blown out through intake tube attachment nut ? or leaking compressor outlet fitting ?
Nino, VA
