Clouddog
Posted: Fri Jul 10, 2020 4:29 am Post subject: YAK 52 gear/flap Indicator Bulbs |
Does anyone have a source for the light bulbs that go into the gear / flap indicators and the master caution panel on a YAK 52? Preferably LED. They are larger than the ones used on a CJ and have two ridges on the bulb case that slides into the light socket.
saber369(at)comcast.net Guest
Posted: Fri Jul 10, 2020 5:15 am Post subject: YAK 52 gear/flap Indicator Bulbs |
Greg, have you tried SuperBright LEDs? https://www.superbrightleds.com/contact
Jon Blake
Saber369(at)comcast.net
http://forums.matronics.com/viewtopic.php?p=497231#497231
fishmouth500
Joined: 07 Apr 2015 Posts: 43 Location: Southern California
Posted: Fri Jul 10, 2020 1:56 pm Post subject: YAK 52 gear/flap Indicator Bulbs |
[img]cid:1733ab6cda3951182621[/img]
Always worth giving those Red Alert advertisers a try😎
How many do you need Greg?
Cheers
John
619 933-2571
www.theyakcollection.com
On Fri, Jul 10, 2020 at 5:34 AM Clouddog <Clouddog22(at)gmail.com (Clouddog22(at)gmail.com)> wrote:
| Quote: | --> Yak-List message posted by: "Clouddog" <Clouddog22(at)gmail.com (Clouddog22(at)gmail.com)>
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
WIKI -
619 933-2571
1.48 MB |
11685 Time(s) |
Alpha-Aviator
Posted: Wed Oct 28, 2020 8:59 pm Post subject: Re: YAK 52 gear/flap Indicator Bulbs |
Hey hey Guys!
Just wanted to chime in with my experience. I ordered 20 of the 3899 BA7S from Jackson Electric Supply. The are the correct bulb but they will NOT fit in the lens. There is a small ridge on the lip of the metal case where it meets the bulb glass.
Unfortunately in a very thorough search, there is NO 24V LED option for these bulbs. I would recommend purchasing through The Yak Collection or Aviaserv.
samll
Posted: Thu Dec 03, 2020 3:58 am Post subject: Re: YAK 52 gear/flap Indicator Bulbs |
| Quote: | Hey hey Guys!
Just wanted to chime in with my experience. I ordered 20 of the 3899 BA7S from Jackson Electric Supply. The are the correct bulb but they will NOT fit in the lens. There is a small ridge on the lip of the metal case where it meets the bulb glass. Also, check out this personal loan affiliate program https://leadnetwork.com/personal-loan-affiliate-program which may help you improve your financial cituation
Unfortunately in a very thorough search, there is NO 24V LED option for these bulbs. I would recommend purchasing through The Yak Collection or Aviaserv. |
so there is no way they could fit in?
Alpha-Aviator
Posted: Fri Dec 04, 2020 7:35 am Post subject: Re: YAK 52 gear/flap Indicator Bulbs |
Yes, they will fit and work if you want to grind or file the lips off each one.
For 3$ more for each, you can purchase bulbs from Yak supporters that are meant for that application and you won’t have to file them down.
Take care.
Jeremy
