IS a COM ANTENNA GROUND PLANE NECESSARY
PostPosted: Wed Jul 01, 2020 10:27 am    Post subject: IS a COM ANTENNA GROUND PLANE NECESSARY Reply with quote
At 12:54 PM 7/1/2020, you wrote:
Yes, the antenna is a simple 1/4 wave whip. The antenna base is mounted in
a wood rib. The antenna base does not touch the steel tube airframe but is
3/4 inch away from a horizontal steel tube and about 6 inches away from a
vertical steel tube, not good I know.
3/4 inch away from an airframe conductor and NOT
electrically attached to it?
So it's all covered up and painted over?
I think an SWR check would be pointless but
perhaps interesting . . . on second thought
maybe important. Hard data on the down-side
of installing an antenna the wrong way is
a teaching moment opportunity.
He's between a rock and a hard place. If
there are builders flying this configuration
and reporting satisfactory performance, it's
going to be difficult/disappointing to wrap
his arms around the next stage. Plan B is an
antenna mounted to a tab which is electrically
common with structure. Try mounting it inside
the fuselage with widest practical separation
from structure/cables.
An SWR check is still a good idea . . . you may
find that proximity effects to the structure
have electrically lengthened the antenna . . .
SWR will minimize at some point below band-center.
If it's under 3:1 overall, leave it alone. If
over 3:1 at the lower edge, you can consider
trimming the tip off in little bits (1/4"
at a time) to bring antenna resonance up
a bit.
I'm noticing that handy little digital VHF/UHF
swr meters are sorta drying up on eBay, et. als.
This is one of my favorites
https://tinyurl.com/ybfyl9fo
it used to be offered by 20 or more suppliers,
could only find a handful of offers
Here's another which would suit our purposes
https://tinyurl.com/ydy327v7
It would be useful for you to track this
builder's experience . . . perhaps we could
craft a 'shop notes' article for archiving
on aeroelectric.com
If getting your own SWR meter is not practical,
I can loan you mine.
PostPosted: Wed Jul 01, 2020 4:42 pm    Post subject: Re: IS a COM ANTENNA GROUND PLANE NECESSARY Reply with quote
Yes, the antenna base is very close to an airframe steel tube but not attached
electrically or physically. The base of the antenna is mounted to a wood rib.
The builder does not know much about electricity or antennas.
And yes, the vertical stabilizer is all covered and painted. The builder will not
want to tear the airplane apart to get that antenna out.
I had forgotten about that Red Dot SWR meter that I had purchased several
years ago and only used once. I found it in my workshop and discovered that
all 3 AAA batteries had leaked. Have you checked your SWR batteries lately?
Luckily the battery holder is mounted with double sided foam tape which
protected the circuit board. I cleaned out the corrosion and installed new
batteries. Luckily the SWR meter still works. I will test my friend's antenna
SWR whenever he gets the RG-58 terminated.
Joe Gores
