Fuel pump Classic
tennant
PostPosted: Sun Jun 28, 2020 2:47 am    Post subject: Fuel pump Classic Reply with quote
I think it is about time to change the mechanical petrol pump on my classic Europa. It looks like the new design Rotax pump will foul the right radiator. Does anyone have experience with this and if so what is the best solution?
Barry
Barry Tennant
D-EHBT
At EDLM - Germany
peterz(at)zutrasoft.com
PostPosted: Sun Jun 28, 2020 3:29 am    Post subject: Fuel pump Classic Reply with quote
Indeed it does. I took mine to a local welder and had him put a 20-ish degree outboard angle on the outlet (?) to clear the new pump. The welding may have resulted in a fin leak, to which i had rectify using JB-weld epoxy, which is working effectively for now until i can source a new custom radiator.
Cheers and good luck!
Pete
On Jun 28, 2020, at 7:11 AM, tennant <barrington.tennant(at)gmail.com> wrote:
Barry
Barry Tennant
D-EHBT
At EDLM - Germany
http://forums.matronics.com/viewtopic.php?p=497062#497062
 Filesize:  106.93 KB
 Viewed:  3986 Time(s)
 Filesize:  123.13 KB
