peterz(at)zutrasoft.com Guest
Posted: Tue Jun 16, 2020 12:29 pm Post subject: N460HJ wouldnt start this am |
Wow! Should be part of the “5 year rubber” service?
Lucky you didnt burn any cyl’s? How were your egt’s? (Or did it just open up all of a sudden?)
Another thing for me to watch for (spares are on my shelf).
Cheers
| Quote: | On Jun 16, 2020, at 3:54 PM, William Daniell <wdaniell.longport(at)gmail.com> wrote:
I should think that i had been flying several times with this.
This is 50hours after a hundred hour check.
The engine which was zero hours had been sitting for about 8 years before i installed it
William Daniell
+1 786 878 0246
<20200614_130803.jpg>
wdaniell.longport(at)gmai Guest
Posted: Tue Jun 16, 2020 2:41 pm Post subject: N460HJ wouldnt start this am |
Well pete interesting that you mentioned that... yes it is and no it was about the only thing i didn't change.
The colombian knowledge based on every climate from temperate to tropical is that rotax carb rubbers are known to fail in hot country. Rotax motors are used and abused (they use them for crop dusting in mxp savannah) in ways that would make most of us blench and giving me a great deal of confidence in rotax engines. the knowledge about what fails and doesnt fail is based on real life. Btw i live in miami.
And yes...very, very lucky. I think cyl burn could have been the best outcome. The worst doesn't bear thinking about.
I posted it so that everyone can learn through my mistake.
Henceforth i shall change every other year and follow buds advice to check closely every 25 hours.
Will
William Daniell
+1 786 878 0246
On Tue, Jun 16, 2020, 16:33 Pete <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)> wrote:
| Quote: | --> Europa-List message posted by: Pete <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)>
Cheers
> On Jun 16, 2020, at 3:54 PM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
> William Daniell
> +1 786 878 0246
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
WIKI -
h&jeuropa
Posted: Wed Jun 17, 2020 2:57 am Post subject: Re: N460HJ wouldnt start this am |
Will,
The photo isn't visible. What failed?
Jim
Posted: Wed Jun 17, 2020 4:08 am Post subject: N460HJ wouldnt start this am |
Jim
Ah ok the matronics server stopped it.
The rubber carb flange....almost completely separated.
So when it would start i opened up the cowling and having checked the plugs and ignition was just about the pull the float bowls off when the carb came off in my hand as it were.
I must have landed with it close to that state. I can only guess that the induction suction plus the turbo airbox kept the carb on in flight.
Will
William Daniell
+1 786 878 0246
On Wed, Jun 17, 2020, 06:59 h&jeuropa <butcher43(at)att.net (butcher43(at)att.net)> wrote:
| Quote: | --> Europa-List message posted by: "h&jeuropa" <butcher43(at)att.net (butcher43(at)att.net)>
Will,
Jim
http://forums.matronics.com/viewtopic.php?p=496877#496877
WIKI -
h&jeuropa
Posted: Wed Jun 17, 2020 9:54 am Post subject: Re: N460HJ wouldnt start this am |
Replacement of the rubber carb flange is called out in the 5 year rubber replacement instruction. There was a revision to the flange that is noted in SB 914-019 R1.
Brett from Leading Edge Air Foils suggested we replace the rubber pad under the expansion tank. It is part no. 860 826. Indeed, when we got it out the old one was rotted.
Jim & Heather
