				 Posted: Sat Jun 06, 2020 6:20 pm    Post subject: Essential Bus Diode Voltage D-25   voltage drop of 2.3V? |
  What should I check to track down this increase in voltage drop?
    Get your voltmeter out, ground the (-) lead and then
    probe the pathway from main bus through the diode
    to the e-bus.
    I've never seen a diode fail in such a manner.  You
    could swap a new one in temporarily as part of the
    investigation but I don't think your going to find
    that to be root cause.
   	  | Quote: | 	 		  Should I just swap in another D-25?  I've been flying for 350hrs.
  Is there another diode of choice now of a Diode I can use to swap in its place?  Where can I purchase the AEC9001 Schottky Power Diode if that's a better option. |
    Pull the fast-ons off the old diode and push them
    onto a new diode without mounting it to get a quick
    voltage check. You're going to have to crawl around
    under there to get at the pathway joints anyhow.
    Return on investment for 'going Schottky' is limited.
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
