				 Posted: Sun Jun 07, 2020 12:33 pm    Post subject: Physical construction of Z101   engine bus &  battery bus |
				At 11:41 AM 6/7/2020, you wrote:
   	  | Quote: | 	 		  | Thanks for the replies. I was not aware of the 9" minimum length on fusible links. Is that somewhere in the Connection?  |
   not yet but will be called out on Z101's notes . . . and probably
   as 6" minimum.
   	  | Quote: | 	 		  | Are crimped butt connectors adequate for connecting the fusible link to the protected wire? |
   Yes
   	  | Quote: | 	 		  | I recently received some of this fusible link wire in both 12 & 14 gauge. Anyone have experience with it? |
   Used on millions of cars for decades. Will be
   testing here on the bench and recording the
   results. Crimped or soldered joints will, I
   trust, prove satisfactory. There is nothing
   magic about the wire . . . it's the insulation
   that makes it special.
