Kelly McMullen
Posted: Sun May 24, 2020 4:28 pm Post subject: Wing Root Fairing |
Perhaps I am missing something in the plans. Section 44 on wing attach has you fit the wing root fairing top and bottom to the fuselage. I recall doing a lot of filing to make this fit, although I don't see any mention now in the plans for having to do that. My question is, I see nothing calling for U-channel or other weather strip. rubber between the wing root fairing and the fuselage. Even with careful fitting you pretty much have to have at least 16" gap. It seems like it might be worth enlarging the gap a little to put some for of rubber there to get an actual seal. What have all y'all done with that?
Kelly
40866
Flying since 2016, getting close to paint shop
| Quote: | | Sent from my TRS-80 Model 100 |
A&P/IA, EAA Tech Counselor
KCHD |
rleffler
Posted: Sun May 24, 2020 4:45 pm Post subject: Wing Root Fairing |
Filed to about a 1/16” gap. Be sure to allow for paint thickness, so my 1/16” gap was probably closer to 1/8” before paint.
Although I do know others that installed a rubber seal too.
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of Kelly McMullen <apilot2(at)gmail.com>
Sent: Sunday, May 24, 2020 8:23:45 PM
To: rv10-list(at)matronics.com <rv10-list(at)matronics.com>
Subject: Wing Root Fairing
Kelly
40866
_________________ Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler |
Lenny Iszak
Posted: Sun May 24, 2020 5:16 pm Post subject: Wing Root Fairing |
I used a rubber j strip fromSpruce. Photo attached.
[img]cid:FFCAC626-578F-4DB8-B9CA-B6FFDA39D14A-L0-001[/img]
Lenny
| Quote: | On May 24, 2020, at 8:35 PM, Kelly McMullen <apilot2(at)gmail.com> wrote:
Kelly
40866
744.15 KB |
11922 Time(s) |
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
kearney
Posted: Sun May 24, 2020 5:42 pm Post subject: Wing Root Fairing |
Kelly
I used edge guard from an auto body shop on both my -10s. Works very nicely.
Cheers
Les
| Quote: | On May 24, 2020, at 7:29 PM, Lenard Iszak <lenard(at)rapiddecision.com> wrote:
<image0.jpeg>
Lenny
Kelly
40866
rjones560xl@gmail.com
Joined: 29 Jul 2015 Posts: 64 Location: Las Vegas, NV
Posted: Sun May 24, 2020 6:01 pm Post subject: Wing Root Fairing |
You can’t put any rubber there. The fairing lays tight against the surface underneath. There is no room for any kind of seal.
Robert Jones
| Quote: | On May 24, 2020, at 5:32 PM, Kelly McMullen <apilot2(at)gmail.com> wrote:
Kelly
40866
_________________ Robert J Jones
702-521-1840 |
philperry9
Posted: Sun May 24, 2020 7:04 pm Post subject: Wing Root Fairing |
I opened it up to about 1/8th inch or so, then installed some U shaped rubber on the wing root fairing. It seals up tight and looks nice.
No issues making it work - easy to do.
Phil
| Quote: | On May 24, 2020, at 9:06 PM, Robert Jones <rjones560xl(at)gmail.com> wrote:
Robert Jones
Kelly
40866
