914 variable oil pressure
MikeP
PostPosted: Thu Jul 02, 2020 9:57 am    Post subject: 914 variable oil pressure Reply with quote
Changed oil and filter a couple of weeks ago and engine has been running fine.
Today got flashing red light from engine management system and variable oil pressure indicated on flydat.
Is this likely to be the oil pressure sensor 'on the way out'?
MikeP
Duncan McFadyean
PostPosted: Thu Jul 02, 2020 10:17 am    Post subject: 914 variable oil pressure Reply with quote
Or the sensor earthing.
You'll only know for sure by using a mechanical gauge to cross-check.
Assuming there's enough oil in the engine!
Duncan mcF
MikeP
http://forums.matronics.com/viewtopic.php?p=497148#497148
