wdaniell.longport(at)gmai Guest
Posted: Wed May 13, 2020 1:56 pm Post subject: John Deere VR |
Dear list
Can someone direct me to a definitive wiring guide for the JD voltage regulator. Ive found it in the past but cant find it now.
Will
William Daniell
LONGPORT
+1 786 878 0246
yellowduckduo(at)gmail.co Guest
Posted: Wed May 13, 2020 2:58 pm Post subject: John Deere VR |
http://www.n56ml.com/corvair/dynamo.html
On 13/05/2020 5:51 PM, William Daniell wrote:
| Quote: | Dear list
Will
William Daniell
LONGPORT
+1 786 878 0246
At 04:51 PM 5/13/2020, you wrote:
| Quote: | Dear list
Will
William Daniell
LONGPORT
+1 786 878 0246 |
what's the part number on your
regulator.
Posted: Wed May 13, 2020 3:32 pm Post subject: Re: John Deere VR |
Can you post a picture of your John Deere regulator?
If it looks like this one, B+ terminal goes to a 30 amp fuse that is connected to the downstream side of battery contactor.
The AC terminals connect to Rotax permanent magnet generator (yellow wires)
L is for a lamp. Usually not used.
IGW connects to a switch (labeled "Alternator") which gets 12 volts from a 3 amp fuse on the main power bus.
Be sure to mount regulator using heat conductive grease between aluminum surfaces.
33.77 KB |
5369 Time(s) |
_________________ Joe Gores |
Posted: Wed May 13, 2020 3:53 pm Post subject: John Deere VR |
I originally bought this as a back up to carry in my flying tool/spares pack. I thought it might be a good idea to know how to install it.
thanks
Will
[img]cid:ii_ka5zpqfi0[/img]
William Daniell
+1 786 878 0246
On Wed, May 13, 2020, 19:03 Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | At 04:51 PM 5/13/2020, you wrote:
| Quote: | Dear list
Will
William Daniell
LONGPORT
+1 786 878 0246 |
regulator.
551.08 KB |
5368 Time(s) |
gilles(at)elixir-aircraft Guest
Posted: Thu May 14, 2020 9:38 am Post subject: John Deere VR |
Le 14/05/2020 à 17:54, William Daniell a écrit :
| Quote: | So my research indicates
AC = Yellow rotax wires output from ALT
B+ = +B = battery
I believe that on the Ducati R and +B are connected internally.
Will,
Yes they are.
http://contrails.free.fr/elec_ducati_en.php
Best regards,
Gilles
