crimp multiple wires into one terminal
johnbright
PostPosted: Tue May 12, 2020 9:19 am    Post subject: crimp multiple wires into one terminal Reply with quote
Hi Bob,
I've seen how you crimp four 22 awg wires into one red (18-22AWG) PIDG terminal and I wonder if this is OK with larger wires and wires of different gages. http://www.aeroelectric.com/articles/multiplewires/multiplewires.html
I'm thinking for example to put a 10 awg and a 4 awg together to save stack height on a contactor or battery stud.
John Bright, RV-6A
Single battery, wound-field alternator on main bus, MZ-30 PM generator on engine/essential bus.
N1921R links
PostPosted: Tue May 12, 2020 11:26 am    Post subject: crimp multiple wires into one terminal Reply with quote
At 12:19 PM 5/12/2020, you wrote:
--> AeroElectric-List message posted by: "johnbright" <john_s_bright(at)yahoo.com>
Hi Bob,
The car-guys do it all the time . . . well . . .
not exactly 'crimped' but it's common to bring
two (or more), largely different gage wires into the same
termination.
You have two design goals:
(1) gas-tight connection between conductor
stranding and the terminal's wire grip barrel.
(2) insulation support to minimize flexing
of the stress riser represented by the
transition from solid (in the grip) to
stranded (in the insulation).
The article I posted about 25 years ago
is still an excellent approach to your
mission:
https://tinyurl.com/ct36xen
This technique is much less critical of
wire/terminal/tool sizing. With the stuff-n-
solder technique, your wire grip can be
quite tight on stranding. In fact, you
purposely 'wedge' the stranding until they
are tight.
Then fill voids in the grip with solder.
Step (1) done.
Finish up with one, perhaps two heat-shrink
sleeves over the terminal and wire to provide
some environmental protection and add mechanical
support. Step (2) done.
I'd stay with welding cable for the really
fat wires . . . tefzel is okay for the smaller
stuff.
Post some pictures of what you end up with.
The fat-wire article could stand to be updated
to include the process you've asked about.
By the way, while surfing for a picture
of a two-wire battery cable, I found what
appears to be an aftermarket product for
replacing battery-post terminal-ends with
. . . who wuda thunk it . . . SOLDERED
attachement.
 Filesize:  15.37 KB
 Viewed:  4622 Time(s)
 Filesize:  16.8 KB
johnbright
PostPosted: Thu May 14, 2020 7:14 pm    Post subject: Re: crimp multiple wires into one terminal Reply with quote
Thanks for the detailed reply Bob.
I'm not far enough along yet but whenever I do get some photos I will post them. Another lister, Jeff Parker, is the one with the issue at present of not having enough stack height on either a battery or contactor stud. Jeff and I have been collaborating on implementing Z-101 onto our respective aircraft with SDS electronic injection and ignition.
Interestingly, Jeff was speaking with a jet aircraft repair technician who mentioned the solder pellet method of attaching a fat wire to a fat lug. This fellow recommended from his experience to crimp after soldering. (Bob responded to this to say don't crimp after soldering, ref http://forums.matronics.com/viewtopic.php?t=16775418&view=previous)
John Bright, RV-6A
N1921R links
