draftsjust417(at)gmail.co Guest
Posted: Sat May 09, 2020 9:29 am Post subject: tach generator upkeep |
Epilogue to my tachometer troubles...
After chasing wires and cleaning connections, I finally disassembled & thoroughly cleaned my hitherto-exposed cannon plug on the Chinese tach generator in the engine compartment.
Redressing the wire run and c.plug with oil resistant tape, it's run like a champ for the last 4 flights.
Fwd and aft gauges in perfect synch.
So, I'm calling the system fixed.
Thx for all the inputs-
Justin
N280NC
On Mon, Apr 6, 2020, 10:29 AM Justin Drafts <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)> wrote:
| Quote: | Great info, thanks...(Mine is the small, engine-mounted variety)
Justin
On Mon, Apr 6, 2020, 9:44 AM Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
| Quote: | Justin;
If you have the later ENGINE mounted Tach. gen. re-greasing of the bearings would be likely a 300-500 hr. unit overhaul function.
If you have the original FIREWALL mounted, cable driven unit, just throw it away and get the later one from Doug Sapp.
Cheers;
Walt
From: Justin Drafts (draftsjust417(at)gmail.com) Sent: Sunday, April 05, 2020 4:49 PM
To: Tom Elliott (N13472(at)aol.com)
Subject: Re: Re: tach generator upkeep
Ok- Any experiences(s) with a good lube/grease for the tach gen bearings? Justin
On Sun, Apr 5, 2020, 1:26 PM Tom Elliott <n13472(at)aol.com (n13472(at)aol.com)> wrote:
