tach generator upkeep
draftsjust417(at)gmail.co
PostPosted: Sat May 09, 2020 9:29 am    Post subject: tach generator upkeep Reply with quote
Epilogue to my tachometer troubles...
After chasing wires and cleaning connections, I finally disassembled & thoroughly cleaned my hitherto-exposed cannon plug on the Chinese tach generator in the engine compartment.
Redressing the wire run and c.plug with oil resistant tape, it's run like a champ for the last 4 flights.
Fwd and aft gauges in perfect synch.
So, I'm calling the system fixed.
Thx for all the inputs-
Justin
N280NC
On Mon, Apr 6, 2020, 10:29 AM Justin Drafts <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)> wrote:
Great info, thanks...(Mine is the small, engine-mounted variety)
Justin
On Mon, Apr 6, 2020, 9:44 AM Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
Justin;
If you have the later ENGINE mounted Tach. gen. re-greasing of the bearings would be likely a 300-500 hr. unit overhaul function.
If you have the original FIREWALL mounted, cable driven unit, just  throw it away and get the later one from Doug Sapp.
Cheers;
Walt
From: Justin Drafts (draftsjust417(at)gmail.com) Sent: Sunday, April 05, 2020 4:49 PM
To: Tom Elliott (N13472(at)aol.com)
Subject: Re: Re: tach generator upkeep
Ok- Any experiences(s) with a good lube/grease for the tach gen bearings? Justin
On Sun, Apr 5, 2020, 1:26 PM Tom Elliott <n13472(at)aol.com (n13472(at)aol.com)> wrote:
Note it reads Engine RPM not prop
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV.
89019
Cell 541-297-5497
N13472(at)AOL.COM (N13472(at)AOL.COM)
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of Justin Drafts
Sent: Sunday, April 05, 2020 8:48 AM
Subject: Yak-List: Re: tach generator upkeep
Morning all,
Fast question re: the Housai's tiny tach generator for prop rpm indication.
In the midst of my cond insp, and the RPA checklist notes the tach gen should be removed and "disassembled and bearings repacked with grease."
I've yet to disassemble one.
Where are these bearings (ie- how get to them)?
What grease have y'all successfully used?
Tach gen maint tips & thoughts much appreciated...
Justin Drafts
N280NC
Seattle
Virus-free. www.avg.com
