Yak-List Digest: 4 Msgs - 05/02/20
bultaco956(at)yahoo.com
PostPosted: Sun May 03, 2020 9:59 am    Post subject: Yak-List Digest: 4 Msgs - 05/02/20 Reply with quote
Larry: I had a shimmy problem in my CJ that bugged me for quite some time. I had the CJ for almost 10 years before it cropped up. It started out as an occasional nuisance and one day it shook bad and did break the splined shaft. OH dampener but still a transient nuisance problem on takeoff and under braking. Over a period of time changed nose tire, balanced nose wheel, changed nose tire again and reversed direction of wheel - that finally fixed it. I believe my root cause was the tendency of the Desser tires to go out of round if left to sit for an extended time particularly if the tire becomes oil contaminated and/or low on pressure. I am more careful caring for my nose tire tire now. BTW there was no doubt the shaft broke the day it let go. Doug has the parts, I did source thin stainless washers elsewhere to shim scissors per PLA MM. Hope this helps.
Jay Wells
1985 CJ6A
On Sunday, May 3, 2020, 05:19:39 AM EDT, Yak-List Digest Server <yak-list(at)matronics.com> wrote:
Today's complete Yak-List Digest can also be found in either of the
of the Yak-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2020-05-02&Archive=Yak
Text Version:
  http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2020-05-02&Archive=Yak
Yak-List Digest Archive
  Total Messages Posted Sat 05/02/20: 4
Today's Message Index:
  1. 05:50 AM - Shimmy vibration? (motoadve)
2. 07:36 AM - Re: Shimmy vibration? (Larry Pine)
3. 10:55 AM - Re: Shimmy vibration? (doug sapp)
4. 03:40 PM - Re: Shimmy vibration? (motoadve)
________________________________ Message 1 _____________________________________
Time: 05:50:16 AM PST US
Subject: Shimmy vibration?
From: "motoadve" <larry(at)motoadventuring.com (larry(at)motoadventuring.com)>
It had happened twice, once landing on grass strip that transitions to pavement,
the nose wheel got back in the air a bit and when it touched down, got lots
of vibration, whole plane shaking.
Second time I did a landing and bounced, (short field and wanted to be down before
I should , had too much energy) when it touched down again lots of vibration,
Both times I thought I had a flat tire.
Take offs , no vibration , and regular landings no vibration, seems to be the nose
wheel does not likes to come back up in the air because the second time it
touches down generates a lot of vibration.
Any ideas what causes this (apart from lousy landing ) Smile
www.Backcountry182.com
Cessna 182 P
CJ -6
http://forums.matronics.com/viewtopic.php?p=496160#496160
________________________________ Message 2  _____________________________________
Time: 07:36:04 AM PST US
From: Larry Pine <threein60(at)yahoo.com (threein60(at)yahoo.com)>
Subject: Re: Shimmy vibration?
Service shimmy dampener=C2-
Sent from Yahoo Mail for iPhone
On Saturday, May 2, 2020, 05:59, motoadve <larry(at)motoadventuring.com (larry(at)motoadventuring.com)> wrote
ment, the nose wheel got back in the air a bit and when it touched down, go
t lots of vibration, whole plane shaking.
before I should , had too much energy) when it touched down again lots of
he nose wheel does not likes to come back up in the air because the second
time it touches down generates a lot of vibration.
Cessna 182 P
CJ -6
S -
WIKI -
=C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin.
________________________________ Message 3 _____________________________________
Time: 10:55:27 AM PST US
From: doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)>
Could be several things:
Linkage worn
Scissors worn
Splined shaft (in damper) sheared
Damper needs overhauled
My guess is that the splined shaft is sheared. I have o/h kits and new
splined shafts if you discover you need them.
Best,
Doug
On Sat, May 2, 2020 at 5:53 AM motoadve <larry(at)motoadventuring.com (larry(at)motoadventuring.com)> wrote:
pavement, the nose wheel got back in the air a bit and when it touched
down, got lots of vibration, whole plane shaking.
down before I should , had too much energy) when it touched down again lots
the nose wheel does not likes to come back up in the air because the second
Cessna 182 P
CJ -6
________________________________ Message 4  _____________________________________
Time: 03:40:07 PM PST US
Thanks Doug, good to hear from you, will keep you posted.
Cessna 182 P
CJ -6
http://forums.matronics.com/viewtopic.php?p=496166#496166
_/Navigator?Yak-List" rel="nofollow" target="_blank">http://www.matronic= - MATRONICS WEB FORUMS= --> http://forums.matronics.com
hnbsp; -Matt Dralle, List Admin.
http://www.matronics.com/contribution</=====================
