neilsenrm(at)gmail.com Guest
Posted: Wed Apr 29, 2020 8:56 am Post subject: Old Kolb Photos |
Flight of 5 planes flying into UL/Light Sport strip Oshkosh 2003. John Williamson - Jabru powered Kolbra, John Hauck - MKIII, Scott Trask MKIII, Rick Neilsen - Redrive VW Powered MKIIIC, ? - 377 powered Kitfox. John Williamson is just finishing his all 50 state landing at Oshkosh. We flew from Iron Mtn. Michigan nonstop. John W wouldn't land for potty breaks because he wanted his first landing in Wisconsin to be at Oshkosh. This was back when they were friendly to flyin planes at the UL strip.
My plane had the high mount engine with the cog belt series two redrive. The next year flying back from Oshkosh the redrive mount brook forcing a landing.
Rick Neilsen
246.15 KB |
3823 Time(s) |
108.43 KB |
3823 Time(s) |
657.41 KB |
3823 Time(s) |
zeprep251(at)aol.com Guest
Posted: Fri May 01, 2020 4:36 am Post subject: Old Kolb Photos |
Rick, I was fairly certain you had worked with Valley on the redrive systems for the VW ,but I never knew you had a inflight failure .where were you when that happened and how did you fix it?
| Quote: | On Apr 29, 2020, at 2:51 PM, Rick Neilsen <neilsenrm(at)gmail.com> wrote:
Rick Neilsen
<100_0861.JPG>
<100_0863small.jpg>
<100_0865.JPG>
