Alternator field control configurations: Death
ventura(at)brandeis.edu
PostPosted: Fri Apr 24, 2020 11:15 am    Post subject: Alternator field control configurations: Death Reply with quote
Bob, please don't die.  I don't know what I would do without you.
--Joel
On Fri, Apr 24, 2020 at 1:02 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
The terms "A-circuit" and "B-circuit" are holdovers from
the days of wound field DC generators. The terms were adopted
to define how voltage applied to the field terminal from
outside affected the output. They've migrated into modern
'alternator speak'.
The terms A and B-Circuit are applicable whether the
alternator is internally or externally regulated.
A fifth configuration is always externally regulated
because BOTH field leads are brought out.
The attached images describe 5 variations of alternator
field wiring:
