Alternator Mod to External Control
PostPosted: Tue Apr 21, 2020 6:27 pm    Post subject: Alternator Mod to External Control Reply with quote
At 02:59 AM 4/21/2020, you wrote:
Hi Bob,
Recently there has been a bit of talk re using an controlling internally controlled alternators. It is very easy to modify them.
In Kitplanes for Nov 2019 I had published an article on how how to modify an alternator (Nippon Denso) with virtually no surgery; and it can be easily restored to standard. Doing this totally eliminates all the hassles with the internally regulated unit. Just use the B&C Regulator.
Graeme Coates
Melbourne, Australia
I've contacted Marc Cook at Kitplanes who has graciously
approved a reprint on AeroElectric.com.
Interested readers can access this nicely illustrated article at:
http://aeroelectric.com/articles/Alternators/NiponDenso_Modification_Nov_2019_Kitplanes.pdf
Dan Fritz
PostPosted: Tue Apr 21, 2020 7:52 pm    Post subject: Re: Alternator Mod to External Control Reply with quote
Thanks Bob, you read my mind!
Dan Fritz
PostPosted: Tue Apr 21, 2020 9:52 pm    Post subject: Re: Alternator Mod to External Control Reply with quote
So I just reviewed the Kitplanes article and it got me thinking of a potentially simpler solution. Please tell me if I'm crazy, but why not just replace the screw in the left brush mount with a non-conductive screw and insert fiber washers to insulate the brush mount from the B-lead. Would this then effectively separate the field from the b-lead and make the field to the internal regulator fully controllable using the already installed IGN connection? What am I missing?
PostPosted: Wed Apr 22, 2020 11:00 am    Post subject: Alternator Mod to External Control Reply with quote
At 12:52 AM 4/22/2020, you wrote:
--> AeroElectric-List message posted by: "Dan Fritz" <Dfritzj(at)yahoo.com>
I'm not intimately familiar with the
brush-holder configuration . . . it's
been some years since I put my hands
on a disassembled ND. Your suggestion
appears to have merit but I would have
concerns about the electrical integrity
of a made-up joint held with a plastic
screw.
jluckey(at)pacbell.net
PostPosted: Wed Apr 22, 2020 11:34 am    Post subject: Alternator Mod to External Control Reply with quote
Interestingly enough, I had just made this mod to a Denso alternator about a week ago, but I had never seen the article Bob references.
I contemplated using a nylon screw (the screw is a metric 3 or 4 mm) but rejected the idea based on the fact that the screw in question is one of two that mounts the brush rig. I deemed that a nylon screw was not strong enough for that duty.  Therefore I used a couple of nylon shoulder washers on the existing steel screw to electrically isolate.
Also,
I rejected the Denso alternator altogether because I found a Ford alternator (from 84 Bronco) that was designed for external regulation.
-Jeff
On Wednesday, April 22, 2020, 12:14:22 PM PDT, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
screw.
kjashton(at)vnet.net
PostPosted: Wed Apr 22, 2020 12:00 pm    Post subject: Alternator Mod to External Control Reply with quote
Here’s another way to mod the alternator, FWIW. It involves desoldering one of the brush wires and sleeving a replacement wire with shrink wrap where it goes through the brush hole in the back of the brushholder. That serves the same purpose as the insulated screw which isolates that side of the brush. The brush holders are cheap so you can experiment.
https://www.canardzone.com/forums/topic/18661-kents-long-ez-project/page/11/?tab=comments#comment-61828
-Kent
On Apr 22, 2020, at 2:57 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
screw.
argoldman(at)aol.com
PostPosted: Wed Apr 22, 2020 7:33 pm    Post subject: Alternator Mod to External Control Reply with quote
Kent,
Thank you for your description and photos of your conversion
It may be my aging eyes but the text in the photos is impossible to read. The device is in perfect focus indicating a possible depth of field problem. If you are using a cell phone focus on the tags. In any case more light will create a greater depth of field and get everything in focus
Thanks again
Rich
On Apr 22, 2020, at 2:55 PM, Kent or Jackie Ashton <kjashton(at)vnet.net> wrote:
-Kent
> screw.
> Bob . . .
Dan Fritz
PostPosted: Wed Apr 22, 2020 10:21 pm    Post subject: Re: Alternator Mod to External Control Reply with quote
Hello All,
I got some non-conductive glass-filled nylon screws (m4 x 10) from McMaster Carr today to test my proposed alternator mod. Photos of my mod are attached below. The mod was extremely simple, just remove the brush holder, loosen the three regulator mount screws, slip a fiber washer between the regulator mount and B-Lead connection, drop the brush holder back in place and replace one of the two screws with the glass-filled nylon one. The whole operation took about 10 minutes to do the first time (probably about 3 minutes after that).
The field terminal is now isolated from the B-lead and appears to work correctly. I wasn't able to spin the alternator up enough on the bench to ensure it still charges correctly and stops charging with removal of the field voltage. I'll have to try that once the engine is running or I find a better bench setup.
Glass filled nylon screws appear to have a tensile strength of 25 ksi and is supposed to be good to 300 degrees F. I plan to disassemble and inspect after about 10 hours of engine run time to see how the screw is faring. If it looks like the screw won't survive, I'll buy a $20 ceramic screw to replace it.
I'll let the group know if this is successful once I can get a solid test of the alternator accomplished. If so, the mod is dead simple and will give full control of the regulator, allowing the traditional crowbar OVP to work as designed.
Alternator Mod.pdf
 Filename:  Alternator Mod.pdf
 Filesize:  285.19 KB
 Downloaded:  409 Time(s)
unitink72(at)gmail.com
PostPosted: Thu Apr 23, 2020 7:47 am    Post subject: Alternator Mod to External Control Reply with quote
Does anyone know which alt is modified in the article?  I tried doing a quick search for Denso alts that they still manufacture new but didn't have any luck.
So far my likely best cadidate for my main alt is from a 95 Dodge van.  Lots of amps, external regulation out of the box.  It does spin the wrong way but thats not a deal breaker for me.
PostPosted: Thu Apr 23, 2020 8:36 am    Post subject: Alternator Mod to External Control Reply with quote
That article is generally applicable to
all ND alternators. The arrangement of
rear-end parts is pretty much common to
the full range of products.
For the most part, auto parts stores
will only carry remanufactured alternators.
Modern re-manufacturing methods are quite
good. Reman alternators are generally as good as
new.
out of the box.
Do you NEED 'lots of amps'? There are few
single engine aircraft that need more than 40A.
30A runs the airplane and 10A reserve charges
the battery. 40A alternators should weigh in
at under 7 pounds.
PostPosted: Thu Apr 23, 2020 8:55 am    Post subject: Alternator Mod to External Control Reply with quote
There are dozens—maybe hundreds--of Denso alternators with slightly different mounts and shapes. A Denso 100211012711 (55 amp) (Honda civic '84-'87, Lester # 14747) will work but it doesn’t fit a Lycoming standard alternator bracket. I make the bracket out of 1/4” mild steel angle. Cut two pieces of angle. Trim and drill for the long alternator mounting bolt, then cut the undrilled legs of the angle to fit the engine, weld them together and drill to match the case holes.
I get them from the junkyard, replace the bearings, brushes and clean up the commutator(?) ring. I use an aftermarket pulley so they don’t turn so fast. There are small Denso models for Kubota tractors and Suzuki Smurai that will also work
-Kent
PostPosted: Thu Apr 23, 2020 9:06 am    Post subject: Alternator Mod to External Control Reply with quote
Josh,
The alternator I got was from a 1978 Suzuki Samurai and is identical (as far as I can tell) to the one in the Kit Planes article.
Also, I believe that Dodge/Chrysler alternators have 'A'-circuit fields. I'm not certain about this, perhaps another lister can confirm? The ideal setup is to have a 'B'-circuit field.
In that Kit Planes article - that Denso alternator is converted from an internally-regulated 'A'-circuit to and externally-regulated 'B'- circuit.
Field Circuit :
A-Circuit - has the regulator in the ground side of the field circuit.
B-Circuit - has the regulator in the 'high' side of the field circuit.
On Thursday, April 23, 2020, 08:56:29 AM PDT, Josh Tinkham <unitink72(at)gmail.com> wrote:
PostPosted: Thu Apr 23, 2020 8:52 pm    Post subject: Alternator Mod to External Control Reply with quote
With an IFR panel and EFI, my math comes out to 50 amps usage worst case with the landing lights and pitot heat on at the same time.  I'm also considering seat heaters.  I understand that a max worst-case shouldn't be my amp requirement.  But I also don't think 40 amps will cut it.  60-70 is the range I'd like to see.
I did not know about the A/B field circuit difference.  Will explore that more, thanks Jeff.
PostPosted: Sun Apr 26, 2020 11:51 am    Post subject: Alternator Mod to External Control Reply with quote
To: Roger&Jean <rnjcurtis(at)charter.net>
Subject: Re: Re: Alternator Mod to External Control
X-Attachments: C:\Users\User\Downloads\2 wire field.jpg;
At 08:19 AM 4/22/2020, you wrote:
Bob,
I didn't see any electrical diagram to show how the 2 new wires are connected to the system.
Roger
This particular mod converts the stock alternator
into a 'universal' field configuration and is
wired like this:
 Filesize:  46.54 KB
 Viewed:  10524 Time(s)
