Magneto and Air Distributor timing
richard.goode(at)russiana
PostPosted: Mon Apr 20, 2020 1:06 am    Post subject: Magneto and Air Distributor timing Reply with quote
I thought I might throw a small pebble into the seemingly now-tranquil waters of magneto discussion!
What is not always known is that while all M9F magnetos have exactly the same timing, there are actually six
different models of the M9-35M, and all with slightly different timing. These variants are identified by a number
which is stamped onto the outside of the magneto case, and the timing for the different variants is given in the
table below.
Setting of the magneto timing
Air distributor timing
Propeller ration
control check
Engine type
Magneto type
Value Stamped into the case
Measured on the crankshaft
Measured on the propeller shaft
On the cranksha ft
On the propeller shaft
M-14 P
M9-25M
23
2,3
1,4
12°
0,658
1,1 mm
24
1,4
26
0,2
0,13
27
-1
-0,4
M-9F
-23 ± 1º
15,8
M9-35M
32
-4,4 ± 0,5°
-2,9 ± 0,5°
33
-5,3 ± 0,5°
-3,5 ± 0,5°
34
-6,2 ± 0,5°
-4,1 ± 0,5°
35
-7,1 ± 0,5°
-4,6 ± 0,5°
36
-8 ± 0,5°
-5,2 ± 0,5°
37
-8,8 ± 0,5°
-5,8 ± 0,5°
RICHARD GOODE AEROBATICS
Rhodds Farm, Lyonshall, Hereford, HR5 3LW, UK
Tel: +44 (0)1544 340120 Fax: +44 (0)1544 340129
e-mail: richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)
www.russianaeros.com
WORLD LEADERS IN RUSSIAN SPORTING AIRCRAFT & ENGINES
In partnership with Aerometal Kft, Hungary.
tigeryak18t
PostPosted: Mon Apr 20, 2020 4:31 am    Post subject: Magneto and Air Distributor timing Reply with quote
Hello Richard
Thank you for this table..
This is incredibly usefull data when needed.
Impossible to find otherwise.
Great thanks for sharing.
Didier
Le lun. 20 avr. 2020 à 11:09, Richard Goode <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)> a écrit :
table below.
Propeller ration
control check
Engine type
Magneto type
On the cranksha ft
M-14 P
M9-25M
23
2,3
1,4
12°
8°
0,658
1,1 mm
24
1,4
26
0,2
0,13
27
-1
-0,4
M-9F
-23 ± 1º
15,8
M9-35M
32
-4,4 ± 0,5°
-2,9 ± 0,5°
33
-5,3 ± 0,5°
-3,5 ± 0,5°
34
-6,2 ± 0,5°
-4,1 ± 0,5°
35
-7,1 ± 0,5°
-4,6 ± 0,5°
36
-8 ± 0,5°
-5,2 ± 0,5°
37
-8,8 ± 0,5°
-5,8 ± 0,5°
____________________________
Didier BLOUZARD
Directeur Général DATEXIS Portable : +33 6 51 84 48 02
Email: didier.blouzard(at)gmail.com (didier.blouzard(at)anolistech.fr)
Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing
