rparigoris
Posted: Tue Apr 27, 2021 10:05 am Post subject: How to seal Tygon tube to barb fittings |
Hi Group. I have a mix of instruments that use various Barb fittings. Some 1 barb, some 2 and some more. Anything Winter or from Germany have gorgeous 2 rounded bump barbs. They don't leak at all. Some of the others with some poking I can get to leak. In the soaring community, if using old tubing or if you suspect leaking, they use a Green Latex farm animal castrating donut. I have some and they work great. Size is 5.5mm ID (.217") x 13.5mm OD (.532"). The Tygon tubing I'm using is 9/32"OD (.281") x 5/32"ID (.156") and depending on barb OD will grow in size. I can only use the Latex rings on about 1/4 of my connections because the rings are so thick (.158"). I would like to use dash 105 O-Rings. I tried a gazillion small clamps, nothing tickles my fancy. ID not right size, too much tension and point loading on wire clamps is 1 on bottom and 2 on top. I tried a double wrap of .25" safety wire, kinda OK but very fiddly to get it just right. You want a complete circle and it needs to go between the point of the barbs so has to be very thin.
Anyway McMaster has A70 durometer dash 105 O-Rings in Buna-N, Viton, Silicone, EPDM and Poly Urethane. They also have harder A90 in Poly Urethane.
Any input on which compound of O-Rings might keep tension better over time when used as a rubber band?
Any other ideas welcomed.
Anyone know of a small circular spring like those used in lips of seals with an approx ID of less than .281"?
Thx. Ron P.
ashleysc(at)broadstripe.n Guest
Posted: Tue Apr 27, 2021 12:08 pm Post subject: How to seal Tygon tube to barb fittings |
Hi Ron;
Viton will probably hold up the best.
Oetiker makes corrosion resistant clamps that hold tight, are light weight, require a special tool to install, and are one-time use.
There is a safety wiring tool that encircles the tubing with 4 wraps of safety wire and folds it over to clench. This is lighter than Oetiker and also one-time use. If you are interested in pursuing this, I can get the name off my tool in the hangar.
Cheers! Stu.
Ceengland
Posted: Tue Apr 27, 2021 12:12 pm Post subject: How to seal Tygon tube to barb fittings |
On Tue, Apr 27, 2021 at 1:32 PM rparigoris <rparigor(at)hotmail.com (rparigor(at)hotmail.com)> wrote:
Quote: | --> AeroElectric-List message posted by: "rparigoris" <rparigor(at)hotmail.com (rparigor(at)hotmail.com)>
Hi Group. I have a mix of instruments that use various Barb fittings. Some 1 barb, some 2 and some more. Anything Winter or from Germany have gorgeous 2 rounded bump barbs. They don't leak at all. Some of the others with some poking I can get to leak. In the soaring community, if using old tubing or if you suspect leaking, they use a Green Latex farm animal castrating donut. I have some and they work great. Size is 5.5mm ID (.217") x 13.5mm OD (.532"). The Tygon tubing I'm using is 9/32"OD (.281") x 5/32"ID (.156") and depending on barb OD will grow in size. I can only use the Latex rings on about 1/4 of my connections because the rings are so thick (.158"). I would like to use dash 105 O-Rings. I tried a gazillion small clamps, nothing tickles my fancy. ID not right size, too much tension and point loading on wire clamps is 1 on bottom and 2 on top. I tried a double wrap of .25" safety wire, kinda OK but very fiddly to get it just right. You want a complete circle and it ne!
Thx. Ron P.
| Something like this?
7mm constant tension hose clamp
You'd need to verify it this particular one applies clamping pressure to a 7mm hose, or it's closed size is 7mm. For more options, just google what I wrote as the link text & substitute the size you want. The flat wrapped springs are quite common in Japanese cars, so you should be able to find something that will work.
My personal preference when using hard polyethylene tubing is to use push to connect fittings. They have a 'rubber' gasket that seals to the *outside* of the tubing, and a metal barb that catches the tubing beyond the sealing point. Easy insertion/removal, unlike barb fittings. Note that you can also find them on ebay, Amazon, etc, usually for a lot less money. If the Tygon you're using is some other, softer material, they probably won't work for you.
Charlie
_________________ Charlie |
steve(at)tomasara.com Guest
Posted: Wed Apr 28, 2021 5:11 am Post subject: How to seal Tygon tube to barb fittings |
Urethane.
Thx. Ron P.
I make a tourniquet using two wraps of lacing cord. Really easy and seems to work fine.
Steve Stearns
O235 Longeze
Boulder / Longmont CO
Posted: Wed Apr 28, 2021 5:13 am Post subject: How to seal Tygon tube to barb fittings |
P.S. I do the same thing for the fuel-line on barbs on my old BMW motorcycle.
Works there too even with the scratched up aluminum barbs.
Steve.
On Wed, Apr 28, 2021 at 7:10 AM Steve Stearns <steve(at)tomasara.com (steve(at)tomasara.com)> wrote:
Urethane.
Thx. Ron P.
Steve Stearns
O235 Longeze
