Kellym
Posted: Mon Apr 13, 2020 6:26 am Post subject: Finish documents |
I received with my finish kit years ago a document on weight and balance
and one on flight testing. First is "W&B RV-10.doc" dated 2/4/05, and
the second is "Flight Test RV-10" dated 3/16/05.
I have never seen an electronic copy of these, nor any update. Just
wondering if they ever have been updated, and if anyone has an
electronic copy, as I just have the one paper copy that came with my
finish kit.
Kelly
40866
Flying since 4/2016
KCHD |
cderk
Posted: Mon Apr 13, 2020 6:39 am Post subject: Finish documents |
It’s part of Chapter 5 of the instructions and available on the electronic version.
| Quote: | On Apr 13, 2020, at 10:31 AM, Kelly McMullen <kellym(at)aviating.com> wrote:
I received with my finish kit years ago a document on weight and balance and one on flight testing. First is "W&B RV-10.doc" dated 2/4/05, and the second is "Flight Test RV-10" dated 3/16/05.
I have never seen an electronic copy of these, nor any update. Just wondering if they ever have been updated, and if anyone has an electronic copy, as I just have the one paper copy that came with my finish kit.
Kelly
40866
Flying since 4/2016
rleffler
Posted: Mon Apr 13, 2020 6:48 am Post subject: Finish documents |
An electronic copy is on the Van's plan CD. The version that I have is dated 2014.
_________________ Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler |
Tim Olson
Posted: Mon Apr 13, 2020 6:52 am Post subject: Finish documents |
Attached is that flight testing document. I have that W&B one too, but
it's too big to post
to the list. I'll email it. It's a scan, so it's big compared to what
an original PDF would
be. Neither is any newer than what you have.
Tim
On 4/13/2020 9:24 AM, Kelly McMullen wrote:
finish kit.
Kelly
40866
Flying since 4/2016
RV10_Flight_Testing.pdf |
229.36 KB |
1093 Time(s) |
Kelly McMullen
Posted: Mon Apr 13, 2020 6:12 pm Post subject: Finish documents |
Thanks everyone. I did find the sources mentioned, and Tim is correct, all electronic versions are still the same 2005 documents, without change.I do have the Van's CD plans...same thing, just harder to find because the plans are merged into one huge file.
I found particularly interesting the discussion in the flight test document of Vne, never mentioning that the number is in true airspeed, not indicated
while most other speeds mentioned are indicated speeds. Just figured they would have incorporated their own white paper on Vne with regard to higher horsepower or turbocharging. | Quote: | | Sent from my TRS-80 Model 100 |
On Mon, Apr 13, 2020 at 7:53 AM Bob Leffler <bob(at)thelefflers.com (bob(at)thelefflers.com)> wrote:
[quote]--> RV10-List message posted by: Bob Leffler <bob(at)thelefflers.com (bob(at)thelefflers.com)>
A&P/IA, EAA Tech Counselor
KCHD |
