Posted: Thu Apr 09, 2020 5:07 am Post subject: Incandescent to led conversion for B&C alternator controll |
At 06:36 AM 4/9/2020, you wrote:
| Quote: | I appreciate everyone's help weighing in on my led conversion but
unfortunately the solution
http://aeroelectric.com/Pictures/Schematics/LR3_LV_Led_1.jpg did not yield
a working result. On the bench the prescribed setup with the resistors and
led will light glow with less than 12 volts. Â
The incandescent bulb glows fine when installed, unplug the incandescent
lamp and plug the led/resistors into the circuit and NO light. |
Is your lamp wired correctly? An LED is
polarity sensitive. Try swapping your
lamp/resistor array wires . . .
