Revisiting a REALLY handy tool . . .
PostPosted: Fri Feb 28, 2020 1:26 pm    Post subject: Revisiting a REALLY handy tool . . . Reply with quote
I think I may have talked about this thingy some
years ago and showed a picture of it. It seems the
thingy in the photo is not to be found having
crawled into the darkest corner of some toolbox.
Needed one for a client project this afternoon.
I built a new one and thought it might be good
to share the rest of the story with the List:
When assembling two or more wires with a solder-sleeve
splice, it's at least a three if not four handed
job. There are a number of soldering-aids for the
workbench that will do the trick . . .but if you're
'in the field' under the hood or behind an instrument
panel, the legacy bench-top Third Hands don't
cut it.
This photo array describes fabrication of a sort
of miniature third-hand. It took only a few
minutes to make and contributed greatly to the
success of my endeavors.
https://tinyurl.com/rjsjghg
If this one gets stored at the front of the
toolbox perhaps I can find it next time . . .
ceengland7(at)gmail.com
PostPosted: Fri Feb 28, 2020 3:11 pm    Post subject: Revisiting a REALLY handy tool . . . Reply with quote
I like. Would it be even more flexible (pardon the pun) if we soldered a 1-2" piece of solid #12 wire between the clips?
Sent from BlueMail
On Feb 28, 2020, at 4:31 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>I think I may have talked about this thingy someyears ago and showed a picture of it. It seems thethingy in the photo is not to be found havingcrawled into the darkest corner of some toolbox.Needed one for a client project this afternoon.I built a new one and thought it might be goodto share the rest of the story with the List:When assembling two or more wires with a solder-sleevesplice, it's at least a three if not four handedjob. There are a number of soldering-aids for theworkbench that will do the trick . . .but if you're'in the field' under the hood or behind an instrumentpanel, the legacy bench-top Third Hands don'tcut it.This photo array describes fabrication of a sortof miniature third-hand. It took only a fewminutes to make and contributed greatly to thesuccess of my endeavors.https://tinyurl.com/rjsjghgIf this one gets stored at the front of thetoolbox perhaps I can find it next time . . . Bohref="http://www.matronics.com/contribution">http://www.matronics/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElp://www.matronics.com/contribution">http://www.matronics.com/contribution
blues750
PostPosted: Mon Mar 23, 2020 6:59 am    Post subject: Re: Revisiting a REALLY handy tool . . . Reply with quote
I wish I had seen this early in my wiring endeavors! Related question to the topic...is there a "best" temperature setting for the heat gun when doing solder sleeve connections? Thanks for posting this Bob - stay healthy!!
Dave
PostPosted: Mon Mar 23, 2020 7:32 am    Post subject: Revisiting a REALLY handy tool . . . Reply with quote
At 09:59 AM 3/23/2020, you wrote:
--> AeroElectric-List message posted by: "blues750" <den_beaulieu(at)yahoo.com>
Dave
Wide open . . . You'll begin to feel sorry
for the wire and shrink before the solder
flows inside.
blues750
PostPosted: Fri Mar 27, 2020 12:09 pm    Post subject: Re: Revisiting a REALLY handy tool . . . Reply with quote
LOL
"...You'll begin to feel sorry
for the wire and shrink..."
Thanks Bob
