cluros(at)gmail.com Guest
Posted: Tue Mar 10, 2020 9:42 am Post subject: Two Radios to One Intercom |
Hello All,
I have been searching through the list archives as I'm sure we have discussed this before but cannot find the exact answer. We currently have a single VHF radio going to an intercom and would like to add a second radio. Input to the intercom would be controlled by the volume knobs on the radios and output will be controlled by a transmit select switch which will only allow the ptt line to be triggered on one radio at a time.
What is required to combine the audio output of the two radios to a single audio input on the intercom?
Thank you,
Sebastien
ceengland7(at)gmail.com Guest
Posted: Tue Mar 10, 2020 10:48 am Post subject: Two Radios to One Intercom |
Simplest way is a ~500 ohm resister in series with each radio's output, and tying the downstream ends together to feed the intercom radio input.
Charlie
Sent from BlueMail
On Mar 10, 2020, at 12:48 PM, Sebastien <cluros(at)gmail.com (cluros(at)gmail.com)> wrote: | Quote: | Hello All,
Thank you,
Sebastien
Posted: Tue Mar 10, 2020 11:19 am Post subject: Re: Two Radios to One Intercom |
Found this drawing someplace.
17.81 KB |
4412 Time(s) |
_________________ Joe Gores |
roughleg(at)gmail.com Guest
Posted: Wed Mar 11, 2020 5:48 am Post subject: Two Radios to One Intercom |
Here is an article on audio mixer circuits. The solutions presented in it involve use of an op-amp, which makes the circuit a little more complicated, but offers advantages in better gain and reduced crosstalk.
https://sound-au.com/articles/audio-mixing.htm
I'm building a mixer for my plane to combine "aux" input (2-channel stereo music, to be mixed to mono) and the alert tone from my EMS into the aux input of my VHF COM radio. This is 3 inputs rather than the two you are looking at, but the principle is the same. Here's the diagram from the article that I plan on using.
[img]cid:ii_k7ndikza0[/img]
Hope this helps.
Pat
On Tue, Mar 10, 2020 at 1:29 PM user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=495222#495222
http://forums.matronics.com//files/audio_combine_160.jpg
WIKI -
12.52 KB |
4379 Time(s) |
