Fwd: Service Bulletin SB 19-09-09 Published - Inspect RV-10
Tim Olson
PostPosted: Fri Feb 28, 2020 9:50 am    Post subject: Fwd: Service Bulletin SB 19-09-09 Published - Inspect RV-10 Reply with quote
I just saw that too, Phil.
I am going to have to give mine a good inspection in that area
and see how it looks. I'm sure it's a high stress area even
if you have nice bushings, but bad bushings wouldn't help
it any. I'm not sure what changes were made. as a guess, I'd think
maybe just thicker ears. If someone finds out, maybe post a pic.
And, if anyone finds cracks, post as well please.
Tim
On 2/28/20 10:07 AM, Phil Perry wrote:
I just saw where this was posted.   Has anyone here seen any of these
issues yet?
I know this area seems to have a lot of play and the bushings are pretty
sloppy.   I had some custom bushings turned to minimize the slop, but it
really didn’t make that much of a difference.    Perhaps the cracks are
caused by an unrelated issue?
Final question.   It sounds like Vans has redesigned the nose gear since
many of us received our kits years ago.  Does anyone know what changes
were made?
Phil
> Service Bulletin SB 19-09-09 Published - Inspect RV-10 gear leg mount
> lug <http://www.vansairforce.com/community/showthread.php?t=179944>
> Van's Aircraft has published a new Service Bulletin for the RV-10,
> SB 19-09-09. This bulletin directs RV-10 owners to inspect the
> inboard attachment lugs on the RV-10 nose gear leg for potential
> cracks at a specific location. If no cracks are found, the gear
> leg is serviceable and you may continue to fly the airplane and
> re-inspect each year at the annual condition inspection.
> Replacement is not necessary in that case.
> If a crack is found, owners are directed to order a kit that
> contains an updated RV-10 nose gear leg and associated hardware.
> This is described in the service bulletin document. continue
> **//___^
glastar(at)gmx.net
PostPosted: Fri Feb 28, 2020 12:47 pm    Post subject: Fwd: Service Bulletin SB 19-09-09 Published - Inspect RV-10 Reply with quote
Looking at the picture in the SB, it seems the inner ears are thicker (Bolt lenght -1 longer)
Further AN6 Bolt instead AN5 and some NAS washers.
[img]cid:part1.5A4EE10B.FC937636(at)gmx.net[/img]
On 28.02.2020 18:47, Tim Olson wrote:
--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com> (Tim(at)MyRV10.com)
it any.  I'm not sure what changes were made. as a guess, I'd think maybe just thicker ears.  If someone finds out, maybe post a pic.
 Filesize:  12.42 KB
 Viewed:  5141 Time(s)
isaac.schantz(at)gmail.co
PostPosted: Fri Feb 28, 2020 1:02 pm    Post subject: Fwd: Service Bulletin SB 19-09-09 Published - Inspect RV-10 Reply with quote
Also, note the lower ears with the WD-1016 attachment.  The extra washers appear to have been removed and what appears to replace them are washers bonded to the bolt attachment ears.
Isaac Schantz
RV-10 Builder #41847
N51279 (Reserved)
On Fri, Feb 28, 2020 at 1:51 PM Werner Schneider <glastar(at)gmx.net (glastar(at)gmx.net)> wrote:
[img]cid:1708d937a46156069151[/img]
 Filesize:  12.42 KB
SB_19-09-09_cropped.pdf
 Filename:  SB_19-09-09_cropped.pdf
 Filesize:  67.2 KB
 Downloaded:  643 Time(s)
