AeroElectric-List Digest: 3 Msgs - 02/07/20
rasmussenre(at)gmail.com
PostPosted: Wed Feb 12, 2020 3:05 pm    Post subject: AeroElectric-List Digest: 3 Msgs - 02/07/20 Reply with quote
Thanks for the response y'all.
Rich, Are you willing to part with your KY97A connector? Sent you a couple
of emails but nothing heard.
Cheers, Robert
Today's Message Index:
1. 11:41 AM - KY97A connector (rasmussenRE)
2. 12:00 PM - Re: KY97A connector (Rich Ulmen)
3. 12:13 PM - Re: KY97A connector (Charlie England)
________________________________ Message 1
_____________________________________
Time: 11:41:54 AM PST US
Subject: KY97A connector
Greetings All,
Anyone know where I can get a 30 pin "edge connector" for a KY97A?
Robert
________________________________ Message 2
Time: 12:00:25 PM PST US
Subject: Re: KY97A connector
I have one. EmAil me
On Feb 7, 2020, at 2:47 PM, rasmussenRE <rasmussenre(at)gmail.com> wrote:
=EF=BB
Greetings All,
Anyone know where I can get a 30 pin =9Cedge connector=9D for a
KY97A?
Robert
~ 1 2 3 4 5 6 7 8 9 10 1112 1314 15
FRONT VIEW - CONNECTOR
(AS SEEN IF VIEWING FROM THE FRONT OF THE RACK) H -------------- - 500
0 AUDIO HI
7 ----------- 500 0 AUDIO LO
J - ---------- MIC AUDIO HI
K - ---------- MIC INTERCOM
9 - ------- MICKEY
8 ------------- MIC AUDIO LO
1 0 - ------------- SQUELCH AND COMPRESSOR DISABLE l - --------------
AGC TEST /REMOTE CHANNEL INC
1 1 - ------------ + 1 3. 7 5 VDC POWER M - ------------- + 1 3. 75
VDC POWER
R- ------------- AIRCRAFT POWER +13.75 VDC
14- ------- AIRCRAFT POWER +13.75 VDC
P --------- - SWITCHED AIRCRAFT POWER
1 3 ------------ - SWITCHED AIRCRAFT POWER N - ------------- XMIT REC
INTERLOCK
12 - ----------------------- REMOTE TRANSFER F ----------------------
AIRCRAFT GROUND
6 ----------------------- AIRCRAFT GROUND S ------------------
AIRCRAFT GROUND
15 ---------------------- AIRCRAFT GROUND B - ----------------- +
14VDC LIGHTING HI
1 ----------------- LIGHTING LO
2 ------------ - DETECTED AUDIO OUT
A ---------------DIM SELECT
E -------------- - 40 AUDIO OUT
5 -------------- 40 AUDIO LO
D - ------------ AUX AUDIO IN 1
C - ------------- AUX AUDIO IN 2
3 - ----------- AUX AUDIO IN 3
4 ---------------- AUX AUDIO IN LO
________________________________ Message 3
Time: 12:13:20 PM PST US
I don't know the radio, but if it's an old pc board edge connector, this
might be worth some research:
https://www.aircraftspruce.com/catalog/avpages/icoma210connector.php?gclid
=CjwKCAiA35rxBRAWEiwADqB377qMQ_OVPp-pqBnsl54hJisWD2Zq76_qewNSDDA7eiT6cYCZ
IGTFjhoCQDUQAvD_BwE
You'd need to verify center-center spacing of the tabs, and overall edge
width. This link might be worth a read as kind of a 'back door' reference:
http://www.vansairforce.com/community/showthread.php?p=1354743
Charlie
On Fri, Feb 7, 2020 at 1:47 PM rasmussenRE <rasmussenre(at)gmail.com> wrote:
Greetings All,
a KY97A?
Robert
H -------------- - 500 0 AUDIO HI
9 - ------- MICKEY
l - -------------- AGC TEST /REMOTE CHANNEL INC
M - ------------- + 1 3. 75 VDC POWER
N - ------------- XMIT REC INTERLOCK
F ---------------------- AIRCRAFT GROUND
S ------------------ AIRCRAFT GROUND
B - ----------------- + 14VDC LIGHTING HI
