Are Huosai magnetos "handed"?
dsavarese0812(at)bellsout
PostPosted: Fri Feb 07, 2020 1:21 pm    Post subject: Are Huosai magnetos "handed"? Reply with quote
Mags are interchangeable left to right/right to left.
Check the high voltage stick for arcing On the sides. This will cause the mag to become inop. Do this b4 you replace the entire mag.
Dennis
On Feb 7, 2020, at 3:27 PM, jay-dub <flyjnw(at)gmail.com> wrote:
I've just had mag failure (number 1) and have managed to source a replacement if necessary. I haven't had chance to diagnose yet so it may just be a short but if it does require replacement, are Huosai mags handed? As in are mag 1 and mag 2 the same or different? The answer determines the next steps.
Thanks.
CJ and Yak-52 owner
http://forums.matronics.com/viewtopic.php?p=494698#494698
PostPosted: Fri Feb 07, 2020 1:57 pm    Post subject: Are Huosai magnetos "handed"? Reply with quote
Also make sure the points are opening and closing. If the points don’t open, the mag will be dead.
Dennis
On Feb 7, 2020, at 4:22 PM, Anthony Savarese <dsavarese0812(at)bellsouth.net> wrote:
Dennis
> Thanks.
> CJ and Yak-52 owner
jay-dub
PostPosted: Sun Feb 09, 2020 1:51 am    Post subject: Re: Are Huosai magnetos Reply with quote
Thanks Dennis, we will do that. The aircraft is stranded away from base so we want to have parts in place if required to avoid doing multiple journeys.
CJ and Yak-52 owner
