David Clark Stereo wiring
John M Tipton
PostPosted: Tue Jan 14, 2020 8:11 am    Post subject: David Clark Stereo wiring Reply with quote
Hi Guys
Where can I find the wiring diagram for a DC stereo headset, the small dia. plug has tip, two rings and the barrel, I have the corresponding panel socket (three contacts plus barrel, I need schematic for the socket wiring.
John
PostPosted: Tue Jan 14, 2020 8:42 am    Post subject: David Clark Stereo wiring Reply with quote
At 10:11 AM 1/14/2020, you wrote:
--> AeroElectric-List message posted by: "John M Tipton" <johntiptonuk(at)hotmail.com>
Hi Guys
John
What is the model number of the headset?
Eric Page
PostPosted: Tue Jan 14, 2020 9:08 am    Post subject: David Clark Stereo wiring Reply with quote
See:
http://www.aeroelectric.com/articles/micjack/micjack.html
On Jan 14, 2020, at 8:11 AM, John M Tipton <johntiptonuk(at)hotmail.com (johntiptonuk(at)hotmail.com)> wrote:
Hi Guys
John
john(at)tipton.me.uk
PostPosted: Tue Jan 14, 2020 9:13 am    Post subject: David Clark Stereo wiring Reply with quote
H10-13.4 & H10-13X, the radio/com is a Trig TY96
John
----x--O--x----
On 14 Jan 2020, at 4:57 pm, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
Hi Guys
John
PostPosted: Tue Jan 14, 2020 10:34 am    Post subject: David Clark Stereo wiring Reply with quote
Unless I’m missing something Eric, that circuit is relating to a ‘Mike’ and PTT circuit, nothing to do with a stereo headphone.
John
----x--O--x----
On 14 Jan 2020, at 5:22 pm, Eric Page <edpav8r(at)yahoo.com> wrote:
See:
Hi Guys
John
John M Tipton
PostPosted: Tue Jan 14, 2020 11:09 am    Post subject: Re: David Clark Stereo wiring Reply with quote
Sorry guys,
I've got this completely wrong way round on the Mike/Headphone situation: so Question, how do I wire up the 1/4" plug for stereo
John
ceengland7(at)gmail.com
PostPosted: Tue Jan 14, 2020 11:32 am    Post subject: David Clark Stereo wiring Reply with quote
On 1/14/2020 1:09 PM, John M Tipton wrote:
--> AeroElectric-List message posted by: "John M Tipton" <johntiptonuk(at)hotmail.com> (johntiptonuk(at)hotmail.com)
Sorry guys,
John
Above is standard stereo wiring for a 1/4" phone plug.
Wiring terminals on the mating jack is kinda tricky to describe, but not complicated. For a novice, the easiest way to ID the terminals is to insert a stereo plug (see above) into the jack, and use an ohm meter to ID continuity from each terminal on the plug, to each terminal on the jack.
Charlie
Eric Page
PostPosted: Tue Jan 14, 2020 12:01 pm    Post subject: David Clark Stereo wiring Reply with quote
Sorry about that, John.  When you wrote "small diameter plug" and "two rings," I thought you were talking about the mic plug. The industry standard mic plug is a 4-conductor TRRS plug of 0.206" diameter (p/n PJ-068), while the headphone is a 3-conductor TRS plug of 0.25" diameter (p/n PJ-055).
According to their data sheets...
http://www.davidclarkcompany.com/files/literature/10-13.4.pdf
and
http://www.davidclarkcompany.com/files/literature/H10-13X.pdf
...both of your headsets use the standard 1/4" PJ-055 stereo headphone plug. As for which contact is left and which is right, perhaps Bob knows the standard in aviation. Internet searching produces plenty of images, some showing tip=left and ring=right, others showing the opposite. The only consistent feature is ground=sleeve.
A quick experiment will quickly reveal which way your headsets are wired.  With the headset over your ears, hold the negative side of a 1.5V battery (coin, AA, AAA) to the sleeve and use a wire connected to the positive side to alternately tap the tip and ring of the headset's plug. You'll know from the static which contact is which. Using this test, my Clarity Aloft is wired tip=left and ring=right.
Eric
On Tuesday, January 14, 2020, 10:53:34 AM PST, John M Tipton <john(at)tipton.me.uk> wrote:
John
PostPosted: Tue Jan 14, 2020 1:10 pm    Post subject: David Clark Stereo wiring Reply with quote
Thank you, that clarifies it
John
  ----x--O--x----
and
Eric
John
Whiteleg
PostPosted: Wed Feb 19, 2020 4:12 am    Post subject: Re: David Clark Stereo wiring Reply with quote
--> AeroElectric-List message posted by: "John M Tipton" <johntiptonuk> (johntiptonuk(at)hotmail.com)
Sorry guys,
John
Charlie
thank you very much and it helped me a lot!
