How to Install Amphenol Connex 122430
art(at)zemon.name
PostPosted: Tue Jan 14, 2020 7:51 pm    Post subject: How to Install Amphenol Connex 122430 Reply with quote
Help!
I bought a 90-degree TNC connector from Aircraft Spruce. It's an Amphenol Connex 122430
https://www.aircraftspruce.com/catalog/elpages/amphenol11-15368.php
and
https://www.amphenolrf.com/122430-10.html
Amphenol's page says that the "contact termination style" is "solder." From the way that the connector is built, it is clear to me that I should solder the center conductor. No problem.
My question: Should I also solder the shield in some way and, if so, how? Or is crimping that sufficient?
We have one afternoon of warm weather tomorrow so I plan to head out to the airport and finish installing my Garmin GPS 175.
    -- Art Z.
https://CheerfulCurmudgeon.com/Love the stranger for you yourselves were strangers in Egypt. Deut. 10:19
ceengland7(at)gmail.com
PostPosted: Tue Jan 14, 2020 8:11 pm    Post subject: How to Install Amphenol Connex 122430 Reply with quote
On 1/14/2020 9:44 PM, Art Zemon wrote:
Help!
and
    -- Art Z.
https://CheerfulCurmudgeon.com/ Love the stranger for you yourselves were strangers in Egypt. Deut. 10:19
That style connector expects that the barrel in the left of the pic will be placed over the coax prior to stripping and soldering. The outer insulation and braid shield should be cut back just enough to allow the center conductor to just reach the center pin in the connector. The center insulator should be trimmed just enough to allow the center conductor to reach the center pin. The knurled barrel pointed left in the pic will be inserted between the coax center insulation and shield, and after soldering the center conductor to the center pin, the outer barrel is slid down against the body of the connector and crimped. The ground connection is made between the knurled surface (mentioned earlier) and the shield braid.
art(at)zemon.name
PostPosted: Wed Jan 15, 2020 4:32 am    Post subject: How to Install Amphenol Connex 122430 Reply with quote
Thanks, Charlie. I can do that.
    -- Art Z.
On Tue, Jan 14, 2020 at 10:27 PM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Help!
and
    -- Art Z.
PostPosted: Wed Jan 15, 2020 8:15 am    Post subject: How to Install Amphenol Connex 122430 Reply with quote
At 09:44 PM 1/14/2020, you wrote:
Help!
and
Yes, the crimp style, right angle connectors
are unique in that one connection (center conductor)
is soldered.
The shield is crimped with a process
and tools common to the series.
That is a crimped shield. It uses the same tools
as the straight connector. For the .195" coax
cables (RG58/141/142/400/LMR195) you need a crimp
tool with a .213" hex die. Installation of a two-crimp
connector is illustrated here:
https://tinyurl.com/shkj3j4
Optimal stripping dimensions for that connector
are given on the customer data sheet:
https://www.amphenolrf.com/downloads/dl/file/id/1510/product/4284/122430_10_customer_drawing.pdf
Striping is really easy with the right tool:
https://tinyurl.com/j6ghop2
I did a quick look-see on youtube for a good
video on this topic. They range from barely
informative to outright wrong . . . I guess
I need to get into the video business . . .
art(at)zemon.name
PostPosted: Wed Jan 15, 2020 9:10 am    Post subject: How to Install Amphenol Connex 122430 Reply with quote
Bob,
No worries. I can handle the details of stipping and soldering and crimping. I just wanted confirmation that I only needed to crimp the shield.
Cheers,
    -- Art Z.
On Wed, Jan 15, 2020 at 10:35 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Help!
and
  is soldered.
PostPosted: Wed Jan 15, 2020 9:46 am    Post subject: How to Install Amphenol Connex 122430 Reply with quote
At 11:07 AM 1/15/2020, you wrote:
Bob,
Cheers,
Good on you my friend . . .
