Leg to fuze fairing
wdaniell.longport(at)gmai
PostPosted: Thu Jan 09, 2020 10:35 pm    Post subject: Leg to fuze fairing Reply with quote
I have a speed kit for my trigear.
I have read on the list of making a faring for the leg to fuze joint.   What is the easiest way to do this?
Will
N460HJ
XS tri
William Daniell
+1 786 878 0246
spcialeffects
PostPosted: Fri Jan 10, 2020 1:33 am    Post subject: Re: Leg to fuze fairing Reply with quote
The easiest way to make a plug for these aircraft is to use blue foam sanded to the desired shape. Then cover in brown tape and lay up on top of that.
DuaneFamly(at)aol.com
PostPosted: Fri Jan 10, 2020 6:05 am    Post subject: Leg to fuze fairing Reply with quote
I have a Europa access but in the conventional gear. Are used modeling clay as a form in which to lay up several layers of BID. Then just some filler, a little sanding, and paint.
Mike Duane
Chandler, AZ
N377EA
On Jan 9, 2020, at 10:35 PM, William Daniell <wdaniell.longport(at)gmail.com> wrote:
Will
N460HJ
XS tri
William Daniell
+1 786 878 0246
rlborger(at)mac.com
PostPosted: Sun Jan 12, 2020 8:35 am    Post subject: Leg to fuze fairing Reply with quote
Will,
I’m waiting for a good response as well. I need to make those fairings and have not found any means with which I am satisfied.
Bob Borger
On Jan 10, 2020, at 12:33 AM, William Daniell <wdaniell.longport(at)gmail.com> wrote:
Will
N460HJ
XS tri
William Daniell
+1 786 878 0246
PostPosted: Mon Jan 13, 2020 3:54 am    Post subject: Leg to fuze fairing Reply with quote
BobYes quite....the flexibility issue is quite an important one....but i wonder how much the legs move in practice so close to the fuze.
Will
William Daniell
+1 786 878 0246
On Sun, Jan 12, 2020, 22:07 Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)> wrote:
--> Europa-List message posted by: Robert Borger <rlborger(at)mac.com>
Will,
Bob Borger
> Thanks
> Will
> N460HJ
> XS tri
> William Daniell
> +1 786 878 0246
br> fts!)
r> > ics.com/contribution
ics.com/Navigator?Europa-List
ronics.com
WIKI -
nics.com
