Wing tip forward aft play tolerance limit?
peterz(at)zutrasoft.com
PostPosted: Sun Jan 05, 2020 8:11 am    Post subject: Wing tip forward aft play tolerance limit? Reply with quote
How much forward aft wingtip play is acceptable? Seems my left wing has more play than the right, the source being the drag strut pip pin assembly. No wear in the bits is observed.
Cheers and thx,
Pete
