Need wing wrap adjuster, kind of like a turn buckle
motoadve
PostPosted: Sun Jan 12, 2020 5:15 pm    Post subject: Need wing wrap adjuster, kind of like a turn buckle Reply with quote
My wing wrap adjuster broke.
Anyone has a spare for sale?
 Filesize:  431.35 KB
 Viewed:  11970 Time(s)
 Filesize:  1.72 MB
 Filesize:  1.72 MB
www.Backcountry182.com
Cessna 182 P
CJ -6
pennington.construction.i
PostPosted: Sun Jan 12, 2020 5:41 pm    Post subject: Need wing wrap adjuster, kind of like a turn buckle Reply with quote
You can find those online.
Look up 4 or 5mm turn buckle.  They are out there as big as 10mm.
These are common items.
Mark
N621CJ
On Sun, Jan 12, 2020 at 8:20 PM motoadve <larry(at)motoadventuring.com (larry(at)motoadventuring.com)> wrote:
--> Yak-List message posted by: "motoadve" <larry(at)motoadventuring.com (larry(at)motoadventuring.com)>
Cessna 182 P
CJ -6
http://forums.matronics.com/viewtopic.php?p=494256#494256
http://forums.matronics.com//files/turnbucklsizee_536.png
http://forums.matronics.com//files/turnbuckle_rezised_2_106.png
http://forums.matronics.com//files/turnbuckle_rezised_2_175.png
br> fts!)
r> > rel="noreferrer" target="_blank">http://www.matronics.com/contribution
          -Matt Dralle, List Admin.
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
WIKI -
b Site -
motoadve
PostPosted: Sun Jan 12, 2020 6:43 pm    Post subject: Re: Need wing wrap adjuster, kind of like a turn buckle Reply with quote
Arent this different?
one threads left the other right?
Cessna 182 P
CJ -6
PostPosted: Sun Jan 12, 2020 7:59 pm    Post subject: Need wing wrap adjuster, kind of like a turn buckle Reply with quote
All turn buckles are made with opposing threads.
On Sun, Jan 12, 2020 at 9:50 PM motoadve <larry(at)motoadventuring.com (larry(at)motoadventuring.com)> wrote:
Cessna 182 P
CJ -6
http://forums.matronics.com/viewtopic.php?p=494258#494258
br> fts!)
FORUMS -
WIKI -
b Site -
dougsappllc(at)gmail.com
PostPosted: Sun Jan 12, 2020 8:17 pm    Post subject: Need wing wrap adjuster, kind of like a turn buckle Reply with quote
turnbuckle??
https://www.google.com/search?rlz=1CABMGD_enUS868US868&sxsrf=ACYBGNRLtKHLKwQVo8YvWV67gI89Csvhww:1578888767648&q=10mm+turnbuckle&tbm=isch&source=univ&sa=X&ved=2ahUKEwjcuoqB2__mAhWIvJ4KHTn1COYQ4216BAgKECM&biw=1536&bih=706&dpr=1.25#imgrc=RXM0rDmuvQj0eM:
On Sun, Jan 12, 2020 at 8:03 PM Mark Pennington <pennington.construction.inc.1(at)gmail.com (pennington.construction.inc.1(at)gmail.com)> wrote:
Cessna 182 P
CJ -6
br> fts!)
FORUMS -
WIKI -
b Site -
PostPosted: Mon Jan 13, 2020 2:06 am    Post subject: Need wing wrap adjuster, kind of like a turn buckle Reply with quote
Doug
Look at the Tower Hobbies Losi Turn buckle set in your link.  Very similar to the adjuster in the wing strap on the CJ.
That style of turnbuckle sometimes is called a stud end turnbuckle from what I found on the internet.
[img]cid:16f9e5c672ccd64c62b1[/img]
On Sun, Jan 12, 2020 at 11:22 PM doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> wrote:
turnbuckle??
Cessna 182 P
CJ -6
br> fts!)
FORUMS -
WIKI -
b Site -
 Filesize:  194.17 KB
 Viewed:  11954 Time(s)
PostPosted: Mon Jan 13, 2020 2:21 am    Post subject: Need wing wrap adjuster, kind of like a turn buckle Reply with quote
Doug
A little more info on the Losi Turn buckle.
Not the common part for the term for sure.  I first saw those when we were building race cars.  We used them all over the car to make adjustments to various linkages.  And we could never find them in SAE thread.   Always metric.  Local speed shops here carry them from 2mm up to 12mm threads.
A pretty common part for the racing crowd.
Not like the turn buckle used to keep your screen door square.  😀
Hope you continue to feel better.  Don’t over do.
Thank you for all you do.
Mark
N621CJ
turnbuckle??
Cessna 182 P
CJ -6
br> fts!)
FORUMS -
WIKI -
b Site -
PostPosted: Mon Jan 13, 2020 8:40 am    Post subject: Need wing wrap adjuster, kind of like a turn buckle Reply with quote
Mark,
Am on the road back to Chemo (Seattle) today, roads are miserable.  If we could discover the correct part number for the one which will fit the CJ I'll stock a few.
Next ship date will be in about 2 weeks.
Best to all,
Doug
On Mon, Jan 13, 2020 at 2:10 AM Mark Pennington <pennington.construction.inc.1(at)gmail.com (pennington.construction.inc.1(at)gmail.com)> wrote:
Doug
turnbuckle??
Cessna 182 P
CJ -6
br> fts!)
FORUMS -
WIKI -
b Site -
 Filesize:  194.17 KB
 Viewed:  11938 Time(s)
PostPosted: Mon Jan 13, 2020 9:17 am    Post subject: Need wing wrap adjuster, kind of like a turn buckle Reply with quote
Doug.
Not sure of the part number.  I can take a look at that next time I have mine out.
Or if Back Country determines a good part number he can share it with you for sure.  He needs one now.
I hope the Chemo goes well for you.  Even on its best day it Chemo sucks.
Call anytime for anything.
Mark
N621CJ
On Mon, Jan 13, 2020 at 11:45 AM doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> wrote:
Mark,
Best to all,
Doug
Doug
turnbuckle??
Cessna 182 P
CJ -6
br> fts!)
FORUMS -
WIKI -
b Site -
 Filesize:  194.17 KB
