Carbon Monoxide test for 914
rparigoris
PostPosted: Sat Dec 14, 2019 11:08 am    Post subject: Carbon Monoxide test for 914 Reply with quote
Hi Group
Has anyone performed the Carbon Monoxide Test as per Rotax to make sure that the leanest cylinder is not too lean when running at 115%? If the answer is yes, what was the richest and leanest cylinder readings and did you need to richen mixture to pass test?
Thx. Ron P.
