any reason NOT to go Swagelok check valves?
jonboede(at)hotmail.com
PostPosted: Wed Oct 16, 2019 1:21 pm    Post subject: any reason NOT to go Swagelok check valves? Reply with quote
I'm a "stock" guy. I like to keep things the way the design bureau designed them.
That having been said, over the years I've replaced or overhauled enough Chinese check valves to fill a trick-or-treater's plastic pumpkin. It's getting old.
The Swagelok replacement check valves seem like a good idea, but I'm cautious, so:
Does anybody have a single experience, observation, or reason NOT to go with the Swagelok replacement one-way check valves?
The only thing I can think of is, "We don't have enough total hours as a community to know what the down-side of the Swagelok valves is going to be" -- but that argument is fading.
Jon
hill(at)doctor-hill.com
PostPosted: Wed Oct 16, 2019 3:01 pm    Post subject: any reason NOT to go Swagelok check valves? Reply with quote
Hello Jon,
It’s a simple thing to rebuild them. Doug Sapp provides the parts and all that’s needed are two 17 mm wrenches. For those check valves that are too far gone from internal corrosion, the replacements that Doug builds are excellent. Regardless, whether you rebuild or replace, they still need to be swapped out every few years. No way around that no matter who makes them.
Just me, but I like to replace the soft lead washer with a soft aluminum crush washer that’s been coated in WD40 to reduce deforming during tightening. Very solid seal. Attached is an image.
Personally, I’m not a big fan of the Swagelok check valves. They are not very robust. Have seen too many fail. On a flight to Oshkosh a few years ago one of the members of our group had several fail by the time we got to Nebraska from Arizona. Spent a long time on the tarmac at the Lincoln airport replacing them with Chinese ones, which kept working for the next three years.
Exceptions are the Swagelok main and emergency on-off valves. They are fantastic and seem to last forever. The 90 degree, 2-port one is SS-42GF2-A-WN2 with the black handle. Attached is an image of one configured for the main air.
Warren Hill
N464TW
Mesa, AZ
[img]cid:8A6EDB2E-8C4B-47DF-B406-C7DE81B0C538[/img]
[img]cid:F9CAE3B5-AB36-4D90-9BD2-A205EC5EA78A[/img]
On Oct 16, 2019, at 2:21 PM, Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:
Jon
 Filesize:  501.81 KB
 Viewed:  5656 Time(s)
 Filesize:  473.27 KB
pennington.construction.i
PostPosted: Wed Oct 16, 2019 3:53 pm    Post subject: any reason NOT to go Swagelok check valves? Reply with quote
Warren
I agree the Chinese check valves.
I use the lead seals and I also use WD40 while tightening.
Do you have a part number for the aluminum seals. ?
Mark
N621CJ
Richmond VA
On Wed, Oct 16, 2019 at 7:08 PM Warren Hill <hill(at)doctor-hill.com (hill(at)doctor-hill.com)> wrote:
Hello Jon,
Warren Hill
N464TW
Mesa, AZ
[img]cid:16dd6faf95b49f117711[/img]
[img]cid:16dd6faf95bdeaecbf52[/img]
Jon
 Filesize:  473.27 KB
 Viewed:  5655 Time(s)
 Filesize:  501.81 KB
PostPosted: Wed Oct 16, 2019 6:39 pm    Post subject: any reason NOT to go Swagelok check valves? Reply with quote
Hello Mark,
The aluminum crush washers are generally available on Amazon, searching first by outer diameter in mm.
Warren
On Oct 16, 2019, at 4:52 PM, Mark Pennington <pennington.construction.inc.1(at)gmail.com (pennington.construction.inc.1(at)gmail.com)> wrote:
Warren
Mark
N621CJ
Richmond VA
Hello Jon,
Warren Hill
N464TW
Mesa, AZ
<Crush_washer.png>
<on-off2.png>
Jon
wlannon(at)shaw.ca
PostPosted: Wed Oct 16, 2019 7:01 pm    Post subject: any reason NOT to go Swagelok check valves? Reply with quote
Hi Mark;
You will find a large selection of both copper and alum. Metric crush washers at McMaster Carr. They are listed by ID, OD and thickness.  I could give you a part number now but not in the hangar so may guess wrong.
I have been using the alum. ones for years for all the check valves and numerous other locations like rocker shafts and various plumbing fittings, etc.
Cheers;
Walt
From: Mark Pennington (pennington.construction.inc.1(at)gmail.com)
Sent: Wednesday, October 16, 2019 4:52 PM
Subject: Re: any reason NOT to go Swagelok check valves?
Warren
Mark
N621CJ
Richmond VA
Hello Jon,
Warren Hill
N464TW
Mesa, AZ
[img]cid:FD652E6ED19944EF85DDFE4671BDCCAD(at)WalterHP[/img]
[img]cid:A47D95B845DE44A8AA1CD1DCAEFB6970(at)WalterHP[/img]
Jon
 Filesize:  501.81 KB
 Viewed:  5650 Time(s)
 Filesize:  473.27 KB
PostPosted: Wed Oct 16, 2019 9:34 pm    Post subject: any reason NOT to go Swagelok check valves? Reply with quote
Thank you Walt and Warren
On Wed, Oct 16, 2019 at 11:07 PM Walter Lannon <wlannon(at)shaw.ca> wrote:
[quote] Hi Mark;
