Wiring dsub connectors
alansbarnett(at)verizon.n
PostPosted: Mon Oct 14, 2019 10:52 pm    Post subject: Wiring dsub connectors Reply with quote
I'm replacing a Narco AT150 transponder with a Stratus ES.?? The wires
running to the Narco, which uses?? are 18 gauge wires and Molex
connectors.?? The Stratus specifies 22 gauge and dsub connectors, but I'm
sure bigger wire is OK.
The problem is crimping the wires.?? I bought a Daniels AFM8 crimping
tool five years ago when I installed a Garmin GNS 430.?? I have the
positioner for 22 gauge wire, but I've lost the positioner for the 18
gauge wire.?? My question is: should I crimp the dsub pins onto 22 gauge
wire and solder the wires to the 18 gauge wires, or spend $50 on a new
positioner (which one? it's hard to tell from the catlogs I've looked
at) so I can crimp the pins directly onto the 18 gauge wires?
Alan
PostPosted: Tue Oct 15, 2019 3:56 am    Post subject: Re: Wiring dsub connectors Reply with quote
Either soldering or crimping is perfectly OK. Yes, soldering will stiffen wire. But that is OK as long as the wire is well supported, which it will be inside of a D-Sub back-shell with wire clamp.
Joe Gores
PostPosted: Tue Oct 15, 2019 12:05 pm    Post subject: Wiring dsub connectors Reply with quote
At 01:42 AM 10/15/2019, you wrote:
--> AeroElectric-List message posted by: Alan Barnett <alansbarnett(at)verizon.net>
I'm replacing a Narco AT150 transponder with a Stratus ES.?? The wires running to the Narco, which uses?? are 18 gauge wires and Molex connectors.?? The Stratus specifies 22 gauge and dsub connectors, but I'm sure bigger wire is OK.
The problem is crimping the wires.?? I bought a Daniels AFM8 crimping tool five years ago when I installed a Garmin GNS 430.?? I have the positioner for 22 gauge wire, but I've lost the positioner for the 18 gauge wire.?? My question is: should I crimp the dsub pins onto 22 gauge wire and solder the wires to the 18 gauge wires, or spend $50 on a new positioner (which one? it's hard to tell from the catlogs I've looked at) so I can crimp the pins directly onto the 18 gauge wires?
That 18AWG citation for the Narco was
overkill. A number of manufacturers have
called out some rather 'conservative'
wire sizes for their DC input pins . . .
a practice that I don't really understand.
None the less, upgrade situations like
you've encountered do present a problem.
I'd splice 22AWG pigtails on the ends of
your 18AWG just before they drop into
the D-sub. This po' boy's solder sleeve
technique works good . . . lasts a long time.
https://tinyurl.com/c5v2xvm
