Dual Band Antenna
rsmith52
PostPosted: Mon Oct 07, 2019 7:46 am    Post subject: Dual Band Antenna Reply with quote
This discussion got me thinking that besides a transponder antenna I needed another antenna for ADS-B in/out. Turns out my thinking was correct for the Garmin equipment I am installing. The GNX 375 is a combination IFR GPS navigator and mode S transponder with ADS-B in/out.
----- Forwarded Message -----
To: Rod Smith <rodsmith52(at)yahoo.com>
Cc: G3Xpert <g3xpert(at)garmin.com>
Sent: Monday, October 7, 2019, 9:28:55 AM MDT
Subject: RE: Antenna for ADS-B In/Out
Rod,
The transponder antenna is all that is needed for ADS-B. You will need a GA 35 GPS antenna for the 375 however.
Please let us know if you have any other questions.
Best regards,
Justin Cobb
Aviation Field Service Engineer
[img]cid:6fa89dba-f60c-f5d4-e9e3-d492e616638c(at)yahoo.com[/img]
1200 E. 151st Street | Olathe, KS 66062, USA | Phone: +1.866.854.8433 | Email: G3Xpert(at)Garmin.com
From: Rod Smith <rodsmith52(at)yahoo.com> Sent: Monday, October 07, 2019 10:06 AM To: G3Xpert <g3xpert(at)garmin.com> Subject: Antenna for ADS-B In/Out
CAUTION - EXTERNAL EMAIL: Do not click any links or open any attachments unless you trust the sender and know the content is safe.
I am about to purchase a G3X system and want to include the GNX 375 in the system. Besides the transponder antenna, what kind of antenna do I need for ADS-B in/out?
Rod
CONFIDENTIALITY NOTICE: This email and any attachments are for the sole use of the intended recipient(s) and contain information that may be Garmin confidential and/or Garmin legally privileged. If you have received this email in error, please notify the sender by reply email and delete the message. Any disclosure, copying, distribution or use of this communication (including attachments) by someone other than the intended recipient is prohibited. Thank you.
 Filesize:  19.97 KB
 Viewed:  5753 Time(s)
PostPosted: Mon Oct 07, 2019 10:28 am    Post subject: Dual Band Antenna Reply with quote
Yes.
My posting last night had some problems
with cut-n-paste of the pictures. I've
formalized the posting as an article
and added some data on the effects
of increasing the width of a 1/4-wave
radiator.
See:
https://tinyurl.com/y48flb9y
I'll suggest that the term "dual-band"
in the cited advertisement is mis-leading.
I think I would call it a "wide-band"
antenna suited for a variety of services
within its performance bandwidth.
PostPosted: Mon Oct 07, 2019 10:30 am    Post subject: Dual Band Antenna Reply with quote
Yes.
radiator.
See:
PostPosted: Mon Oct 07, 2019 10:31 am    Post subject: Dual Band Antenna Reply with quote
of increasing physical width of a 1/4-wave
radiator.
See:
