jonboede(at)hotmail.com Guest
Posted: Sun Oct 06, 2019 5:40 pm Post subject: Very odd gear behavior |
Flying a stock CJ, put the gear handle up and small pfffft and the gear stays locked down.
Put the gear handle in down and land, no issues.
Take the bird and put it on the jacks in the hangar. Start with zero air, put the gear handle up, slowly add air from the filler port and the gear comes up just fine.
Ok, so maybe it was just a gremlin... go fly. Air now at full pressure, put gear handle up and pffft ... nothing. Gear stays locked down. Try the read gear handle and small pfffft and gear stays down. Read gear to middle, try front again and gear stays down.
Put the gear handle down and land, no issues.
Any systems geniuses want to take a guess at what’s up??
Jon
rickkelleyfly(at)gmail.co Guest
Posted: Sun Oct 06, 2019 6:21 pm Post subject: Very odd gear behavior |
One way check valve from the emer side is bad.
| Quote: | On Oct 6, 2019, at 7:39 PM, Jon Boede <jonboede(at)hotmail.com> wrote:
Jon
Posted: Sun Oct 06, 2019 6:27 pm Post subject: Very odd gear behavior |
The emergency side check valve is most likely allowing air pressure from
the emergency system to move the diverter valves; thus blocking the main
side. It's just like opening the emergency air valve and moving the
diverter valves. Unless you bleed off the air pressure after you close
the emergency air valve, when you attempt to retract the gear, the gear
will not retract because the diverter valve is blocking the main side
air pressure.
A. Dennis Savarese
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 10/6/2019 9:39 PM, Jon Boede wrote:
Jon
Posted: Sun Oct 06, 2019 6:37 pm Post subject: Very odd gear behavior |
One other test you can do is, with the main and emergency valves fully
closed, squeeze the brake handle until your deplete all the air/until
you can no longer hear the "woosh" sound when you release the brake
handle. Next, let the airplane sit for at least 4 hours. Then when you
come back to the airplane, immediately go to the cockpit and squeeze the
brake handle. If you hear the "woosh" sound again, you'll know you have
either a leaking emergency air valve or as previously mentioned, a bad
check valve.
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
On 10/6/2019 10:20 PM, Richard Kelley wrote:
> Jon
wlannon(at)shaw.ca Guest
Posted: Sun Oct 06, 2019 7:43 pm Post subject: Very odd gear behavior |
Hi Richard;
Dennis has you on the right track here but I am attaching a sketch with the
location of the the check valve that may have failed internally and is
leaking NORMAL system air into the EMERG. operating system.
That is assuming you did NOT do an Emergency down test prior to flight and
failed to bleed the system as Dennis described.
Walt
604.68 KB |
14519 Time(s) |
draftsjust417(at)gmail.co Guest
Posted: Mon Oct 07, 2019 4:14 am Post subject: Very odd gear behavior |
Fast question... what's the emergency air bottle gauge reading? Getting any lower, or fluctuating?
Why I ask: years ago I had a similar issue where a check valve on Emer Air side had corroded, letting emergency "down" air
bleed into the system to oppose the "up" from the normal side. LG wouldn't budge going up.
Replaced the faulty check valve and all was fine afterwards.
Regardless, I'm sure it's a straightforward snag to fix, just got to find the gremlin...
Justin Drafts
N280NC
Seattle
On Mon, Oct 7, 2019 at 6:15 AM Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:
| Quote: | --> Yak-List message posted by: Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)>
Jon
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
WIKI -
Posted: Mon Oct 07, 2019 4:15 am Post subject: Very odd gear behavior |
Oop, I see my comments came well after lots of good advice.. Justin
On Mon, Oct 7, 2019 at 4:42 PM Justin Drafts <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)> wrote:
| Quote: | Fast question... what's the emergency air bottle gauge reading? Getting any lower, or fluctuating?
Justin Drafts
N280NC
Seattle
Jon
WIKI -
ed.kettler
Joined: 27 Oct 2018 Posts: 19 Location: Fort Worth TX
Posted: Mon Oct 07, 2019 5:02 am Post subject: Re: Very odd gear behavior |
Hi guys,
The emergency system was not activated. Both cockpit gauges show Emergency Air at 55 atmospheres, and they never go down, even after weeks of sitting
Thanks for all of the help! It is much appreciated!
Ed
_________________ Ed Kettler
N53HM |
carl.benda
Joined: 14 Aug 2017 Posts: 12 Location: Colorado Springs
Posted: Mon Oct 07, 2019 6:29 am Post subject: Very odd gear behavior |
Just went through that issue, check valves on the firewall.
Carl Benda
Jon
_________________ Carl Benda
Nanchang N87CJ
Nanchang N4184G |
