ASI Accurcay Dynon Pilot Head
Matt Dovey
PostPosted: Thu Sep 26, 2019 10:17 am    Post subject: ASI Accurcay Dynon Pilot Head Reply with quote
Evening All,
Has anyone fitted a Dynon heated pitot head and then performed the LAA's ASI calibration. Using the heading method.Then inputted the data into their Excel spread sheet? If so what sort of accuracy did you get. The spread sheet is using certified aircraft standards for ASI error tolerances. I've had some leaks that I've sorted out. But I'm still fairly far outside the tolerance.
carlp101
PostPosted: Mon Nov 04, 2019 3:51 pm    Post subject: Re: ASI Accurcay Dynon Pilot Head Reply with quote
Hi Matt,
I've fitted the Dynon heated pitot and performed the calibration using the heading method. It was very accurate. Well within the requirements.
Carl
Matt Dovey
PostPosted: Mon Nov 04, 2019 10:18 pm    Post subject: Re: ASI Accurcay Dynon Pilot Head Reply with quote
Hi Carl,
I've been working through the problem with the LAA. I've had to move my static source. I'm nearly there now.
Where abouts did you fit you static port?
Matt
carlp101
PostPosted: Tue Nov 05, 2019 2:20 am    Post subject: Re: ASI Accurcay Dynon Pilot Head Reply with quote
Under the fuselage below the ADAHRS behind the rear parcel shelf.
