Yellowhammer
Joined: 21 Mar 2018 Posts: 101 Location: Franklinton, Louisiana
Posted: Mon Aug 26, 2019 9:29 am Post subject: Fuel Tank Advice |
Dear Pulsar Friends,
I have question regarding my fuel tank setup.
I have delayed installing my tank (header tank for 582 Rotax), because I am trying to find an alternative to the sight tube gas gauge as I feel it isn't a good design.
I am looking to place a Fuel Sending unit centered in the upper section of the back gas tank panel. There are so many different types available but I feel I will need either a mechanical float type of capacitance type.
I know I will have to mount it horizontally in the back and most probably have to bend the capacitor in order to get an accurate reading.
Could someone impart some wisdom my way so I can determine what will be the most acceptable way of installing this system?
Should I install a fuel pump? My original thinking says I do not need to but it never hurts to ask.
I would also like to install a gas-collator or some other device to check for water and debris in the fuel tank. In short, I feel I need to sump the fuel before each flight.
Any and all words of wisdom, advice, or ideas will certainly be valued and most appreciated!
Sincerely and Respectfully,
Clyde
| - The Matronics Pulsar-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Pulsar-List |
_________________ J.M. Oyler "Clyde" |
ronko(at)att.net Guest
Posted: Mon Aug 26, 2019 12:55 pm Post subject: Fuel Tank Advice |
Clyde,
I didn't build my Pulsar (582 w/header tank), but since my ownership, I have changed out the mechanical fuel sender to a capacitive sender, added a Facet electric auxiliary fuel pump, added the experimental aircraft gas-collator and a fuel flow monitor.
The capacitive fuel sender works, but the fuel flow monitor is extremely accurate as long as you update the gauge, when you top off the fuel tank. I have calibrated the capacitive sender multiple times, and then later, half a tank can read half other times closer to 3/4.
Having previously owned commercially built aircraft, I am one to believe there is a good reason they have gas-collators and auxiliary fuel pumps. For experimental aircraft, these items are not that expensive for the peace of mind. Debris does occasionally show up at preflight sumping the fuel and mechanical fuel pumps can stop working (I did have this happen).
Best regards,
Ron
On Monday, August 26, 2019, 12:30:19 PM CDT, Yellowhammer <coyler(at)sthpk-12.net> wrote:
--> Pulsar-List message posted by: "Yellowhammer" <coyler(at)sthpk-12.net (coyler(at)sthpk-12.net)>
Clyde
J.M. Oyler "Clyde"
http://forums.matronics.com/viewtopic.php?p=491058#491058
= the many List utilities such as List Un/Subscription,
http://forums.matronics.comhttp://wiki.matronics.com
http://ww======
Yellowhammer
Posted: Tue Aug 27, 2019 8:12 am Post subject: Re: Fuel Tank Advice |
Ron,
Thank you so much for the advice. It make me feel much better and now I know how to proceed!
Clyde
Yellowhammer
Ron,
Clyde
