Anyone else driving a TruTrak AP with a GRT HX or HXr EFIS?
Mauledriver(at)nc.rr.com
PostPosted: Tue Aug 27, 2019 9:27 am    Post subject: Anyone else driving a TruTrak AP with a GRT HX or HXr EFIS? Reply with quote
Looking for anyone else with flying with these components to see if they
are experiencing any wing rocking (or not).
I have been experiencing a persistent wing rocking problem in my
installation for a number of years.  It's become less tolerable as I've
become more demanding of my aircraft's performance.  The problem has
been mentioned here before but is fully documented  on the GRT board.
The question is specific to TruTrak and GRT.  It's become clear that
this is not a problem with other product configurations.
Thanks!
Bill "deep into maintenance and incremental improvement mode, 1100hrs
and counting" Watson
d.j.goneflyin(at)earthlin
PostPosted: Tue Aug 27, 2019 9:53 am    Post subject: Anyone else driving a TruTrak AP with a GRT HX or HXr EFIS? Reply with quote
Hi Bill,
When you slave the AP to the GRT HX and have the enav setting you will get the rocking problem. Set your HX to gnav and this will solve your problem.
David Jones
N331DJ
Cell: 941-661-4926
On Aug 27, 2019, at 1:25 PM, Bill Watson <Mauledriver(at)nc.rr.com> wrote:
Looking for anyone else with flying with these components to see if they are experiencing any wing rocking (or not).
I have been experiencing a persistent wing rocking problem in my installation for a number of years. It's become less tolerable as I've become more demanding of my aircraft's performance. The problem has been mentioned here before but is fully documented on the GRT board.
The question is specific to TruTrak and GRT. It's become clear that this is not a problem with other product configurations.
Thanks!
Bill "deep into maintenance and incremental improvement mode, 1100hrs and counting" Watson
flysrv10(at)gmail.com
PostPosted: Tue Aug 27, 2019 10:53 am    Post subject: Anyone else driving a TruTrak AP with a GRT HX or HXr EFIS? Reply with quote
Bill,
I had Gimini that had your problem. I do not have GRT. Trutrak replaces my unit (after many trouble shooting flights) and my problem went away.
You might also try your setting at max and work your way down to see if it helps.
Do not archive.
Thanks!
