Fwd: flight
lcottrell
PostPosted: Sat Aug 17, 2019 10:06 am    Post subject: Fwd: flight Reply with quote
My first attempt was not sent to the list- too big. So I will send the pictures in three files. They have been reduced in size quite a bit, so I think it was volume rather than size. I have been wrong before however.
After checking the weather and winds, I decided to go fishing on the Owyhee River. The spot that I like is about an hour away by Firestar 2. I really haven't been flying all that much this year and my conscious was bothering me. Every thing started out quite nicely and I had a bit of a tail wind at 5K. As I approached the half way point the winds kicked up and I was all over the sky I persisted for a few miles and it got even rougher. Things tend to get worse here as the hours near the midday point, so I gave up and turned back for home. As I reversed my course I dropped some in altitude as the winds at 6 k were supposed to be 12 to 19 MPH. I noticed several bunches of feral Horses below. I did not have a real camera so I did what I could with the low resolution screen shots from my Garmin Virb. I am used to seeing some fairly "flashy" feral Horses in some of these herds, but today there was about 6 white ones. They as near as I can tell are not albino, but are white with "creamy" tails and manes.
I will fish another day however, when it is not so drafty. Some of the shots are just scenery, the last four have horses in them if you can find them.
Larry
 Filesize:  1.16 MB
 Viewed:  3022 Time(s)
 Filesize:  1.34 MB
 Filesize:  1.32 MB
