wdaniell.longport(at)gmai Guest
Posted: Thu Aug 15, 2019 4:45 am Post subject: Socket size of wheel nut |
Im being lazy. Does anyone know the size the main gear wheel nut? (In recent maintenance involving several people mine disappeared, i suspect it took a trip, as thing often do in that situation)Many thanks will
William Daniell
+1 786 878 0246
Ivor
Posted: Thu Aug 15, 2019 5:44 am Post subject: Re: Socket size of wheel nut |
Yes it’s 1 5/16 inch same size as an old Austin mini flywheel bolt
Posted: Thu Aug 15, 2019 2:02 pm Post subject: Socket size of wheel nut |
Hahaha....i was not aware of that.Thanks ivor
William Daniell
+1 786 878 0246
On Thu, Aug 15, 2019, 08:47 Ivor <g-iver(at)live.co.uk (g-iver(at)live.co.uk)> wrote:
| Quote: | --> Europa-List message posted by: "Ivor" <g-iver(at)live.co.uk (g-iver(at)live.co.uk)>
http://forums.matronics.com/viewtopic.php?p=490884#490884
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
WIKI -
budyerly(at)msn.com Guest
Posted: Fri Aug 16, 2019 10:51 am Post subject: Socket size of wheel nut |
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]-->
A lovely old tool worth having on a trigear is Ford Wrench with the extended jaw, but hard to find since it went out of production in the 30s. A similar wrench that works great is a parallel jaw, adjustable wide grip wrench used by plumbers. Works the same just the handle is radial rather than parallel. With a shaft/pipe inserted into your wheel, you can’t get a socket on the Matco nut. With one of these wrenches, it is easy to adjust and remove the axle nut on both the new nose gear axle and then slide the nut/washer, and whole wheel off the spindle, then block the spindle with a couple 4x4 blocks. See above how the jack and pipe into the spindle setup works.
Here is the radial wrench: Typically around $15.
Best Regards,
Bud Yerly
Sent from Mail for Windows 10
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of William Daniell <wdaniell.longport(at)gmail.com>
Sent: Thursday, August 15, 2019 8:43:06 AM
To: europa-list(at)matronics.com <europa-list(at)matronics.com>
Subject: Socket size of wheel nut
Im being lazy. Does anyone know the size the main gear wheel nut? (In recent maintenance involving several people mine disappeared, i suspect it took a trip, as thing often do in that situation) Many thanks will
William Daniell
+1 786 878 0246
19.28 KB |
6509 Time(s) |
1.56 MB |
6509 Time(s) |
DuaneFamly(at)aol.com Guest
Posted: Fri Aug 16, 2019 1:42 pm Post subject: Socket size of wheel nut |
I think they call that a Basin Wrench. Available at any Home Depot or Lowe’s.
On Aug 16, 2019, at 11:49 AM, Bud Yerly <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
| Quote: | v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]-->
<A08138C5550E42DD81FABDE48FCEA4BA.jpg>
Best Regards,
Bud Yerly
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) <owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)> on behalf of William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)>
To: europa-list(at)matronics.com (europa-list(at)matronics.com) <europa-list(at)matronics.com (europa-list(at)matronics.com)>
William Daniell
+1 786 878 0246
<100_0128.jpg>
Posted: Fri Aug 16, 2019 6:33 pm Post subject: Socket size of wheel nut |
Thats pretty neat....thank you. Up to now ive used an exhaust clamp on the
lower leg as a jacking point but your solution is much better.
Will
On Fri, Aug 16, 2019, 15:00 Bud Yerly <budyerly(at)msn.com> wrote:
[quote] A lovely old tool worth having on a trigear is Ford Wrench with the
