A Video to Change Basic Concepts
duanefamly(at)aol.com
PostPosted: Fri Sep 20, 2019 9:04 pm    Post subject: A Video to Change Basic Concepts Reply with quote
A fellow EAA member in my group posted this video. Very much worth a view. Changes a couple of very basic rules that we fly by and may be putting us in jeopardy.
https://m.youtube.com/watch?v=m_tKShlf_gU
Feedback would be very welcomed. A discussion would be welcomed also.
Mike Duane
Europa XS Conventional Gear
N377EA Las Vegas, NV
EAA 1300
Sent from Windows Mail
AirEupora
PostPosted: Sun Sep 22, 2019 8:35 am    Post subject: Re: A Video to Change Basic Concepts Reply with quote
Duane, not a bad video. After teaching for the last sixty years the FAA has dumb down the ACS to the point I had to write a letter to the FAA, but it did no good. Stalls are still killing people. When you watch this video he is trying to get pilot to go to a safe airspeed, which I have no problem with. Some GA pilot never practice stalls and when it does happen they don't believe it and delay the recover. The Cessna' are hard to get into a spin, but once they in it. You can let go and it will recover itself if rigged correctly. My Europa would stall at 44 knots and break straight down. On the power on stalled it was very difficult to get a good stall as it would start turning to the left and stay right on the edge of the stall. Never span it as the book said not to.
Having a quick reference line on the airspeed is a good Ideal, but I had an MGL EFIS installed and not sure how I could mark it..
The best thing on the market is an AOA (Angle of Attach). I first saw this in action back in Korea. Back seating in a F-4. The pilot flew the whole pattern with the AOA at 14 degrees. The tone was just on and he showed me the indicator was in the yellow range.
The MGL had a AOA and it worked very nicely during flight maneuvers. In the traffic pattern I'd fly at 85 knots then slow to put flaps out. I'd get a tone and an indication on the screen of my attitude. As I came in for landing the tone would get high and the indicator would go red as I approached a stall.
I have ten airplane on my flight line and it cost 3k just to install an certify AOA. What the guy in the video is doing is setting a safe speed on the airspeed indicator.
A lot of the newer aircraft are coming from the factor with an AOA.
