BNC connectors - Types of cable and installation tools
Argonaut36
PostPosted: Sun Jul 14, 2019 3:00 pm    Post subject: BNC connectors - Types of cable and installation tools Reply with quote
Could somebody kindly answer the following questions:
- Are BNC connectors for RG-58U wire and RG400U wire the same?
- Can the same crimpers be used for attaching BNC connectors to both RG-58U wire and RG400U wire? If so, why you can only read ‘58’ on some dye sets and not ‘58/400’ or something like that?
- What about TNC connectors? Do the same principles as for BNC connectors apply when it comes to RG58/RG400 cables and installation tools?
argoldman(at)aol.com
PostPosted: Sun Jul 14, 2019 5:42 pm    Post subject: BNC connectors - Types of cable and installation tools Reply with quote
There is a difference between the 58 and the 400 RU B(T)NC connectors
It deals with the fact that the ‘400 cable has 2 braided shields around the central insulated conductor. This makes the wire greater in diameter and thus needs a larger crimp collar(which holds the whole assembly together). You could probably get by using a 400 collar with 58 wire but a 58 collar won’t easily fit in 400.
The crimping tools should be the same.
Rich
The crimped
http://forums.matronics.com/viewtopic.php?p=490290#490290
Argonaut36
PostPosted: Mon Jul 15, 2019 6:01 pm    Post subject: Re: BNC connectors - Types of cable and installation tools Reply with quote
Thanks for answering my questions!
