insulating boots for contactors
kenryan
PostPosted: Mon Jul 01, 2019 10:23 am    Post subject: insulating boots for contactors Reply with quote
What is the best way to insulate a positive contactor terminal with more than one wire connected? The rubber insulating boots that I have seen are made to be used with a single wire on the terminal.
Ken
PostPosted: Mon Jul 01, 2019 11:08 am    Post subject: insulating boots for contactors Reply with quote
I suggest you not worry about it. We had
some discussions about this waaayyy back when.
One builder suggested building a cover for the
contactor intended to shield 'dangerously
exposed terminals' from accidental contact/shorts.
Bad idea . . . these critters run warm NORMALLY
and are designed to perform in 'open to
the environment' conditions. Any enclosure
could emulate a tiny oven where the contactor
is deprived of expected air flows.
[img]cid:.0[/img]
Consider this picture I took on the A36
production line at Beech. Talk about
spark-hazard-city! Yet, just like the
bus bars behind the breakers, these
are considered to be exceedingly unlikely
sources for sparks-in-the-dark . . . or
otherwise.
 Filesize:  228.74 KB
 Viewed:  3371 Time(s)
Eric Page
PostPosted: Mon Jul 01, 2019 11:17 am    Post subject: insulating boots for contactors Reply with quote
I don't know about "best," but self-amalgamating silicone tape makes a good insulator for pretty much any size or shape terminal. It's available on eBay for cheap, or under the trade name "Rescue Tape." If you're not familiar, it's a tape with no adhesive that sticks only to itself. Stretch it as you wrap it, and it sticks instantly and permanently.
Eric
On Monday, July 1, 2019, 12:05:42 PM PDT, Ken Ryan <keninalaska(at)gmail.com> wrote:
Ken
kenryan
PostPosted: Tue Jul 02, 2019 6:07 am    Post subject: insulating boots for contactors Reply with quote
Okay then! I'll forego the rubber boots.
On Mon, Jul 1, 2019 at 11:14 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[img]cid:16bb300e06be68f68cb1[/img]
  otherwise.
 Filesize:  228.74 KB
 Viewed:  3360 Time(s)
