Posted: Thu Jun 27, 2019 2:21 pm Post subject: Time's Toll has taken a Toll on my Oil Door |
Passing throught 1150 hours, it appears that my oil door latches are
wearing through the hatch edges. I've attached a picture approximating
my installation (thanks to Brian and Brandi for the image).
Despite the metal to metal contact of the button latch, pressure and
vibration has slowly worn thru the thin piece of steel I had inserted
into the edge of the hatch to bear on the latch. It hasn't completely
failed yet but will shortly. Working on a new hold down method. (I know
from previous experience that a open hatch will remain open but in
place while in flight).
The hatch, despite double skinning and all, was never stiff enough to
maintain a good fit in flight. There's a lot of air pressure trying to
push it out. May work on a short term and a longer term fix.
Just FYI folks.
Bill "realizing a 1100 hour, 8 year old '10 is not longer my a new
plane" Watson
68.1 KB |
7225 Time(s) |
cderk
Posted: Fri Jun 28, 2019 3:13 am Post subject: Time's Toll has taken a Toll on my Oil Door |
Sorry to hear this, Bill. I actually just got done fitting all the parts on my oil door in a similar manner.
I know this is completely unrelated, but I’m wondering how others have built up epoxy/flox on the top of the camlocs. Seems like somehow you need a “mold”, but I havent figured out how to do this without the epoxy sticking to everything. I took a few pieces of aluminum sheet that approximated the thickness of the oil door and cleco’d the camlocs on there... wasn’t able to get them out without boogering up the epoxy after it dried.
| Quote: | On Jun 27, 2019, at 6:20 PM, Bill Watson <Mauledriver(at)nc.rr.com> wrote:
Passing throught 1150 hours, it appears that my oil door latches are wearing through the hatch edges. I've attached a picture approximating my installation (thanks to Brian and Brandi for the image).
Despite the metal to metal contact of the button latch, pressure and vibration has slowly worn thru the thin piece of steel I had inserted into the edge of the hatch to bear on the latch. It hasn't completely failed yet but will shortly. Working on a new hold down method. (I know from previous experience that a open hatch will remain open but in place while in flight).
The hatch, despite double skinning and all, was never stiff enough to maintain a good fit in flight. There's a lot of air pressure trying to push it out. May work on a short term and a longer term fix.
Just FYI folks.
Bill "realizing a 1100 hour, 8 year old '10 is not longer my a new plane" Watson
<Oil Door Brian and Brandi.jpg>
Dave Saylor
Posted: Sun Jun 30, 2019 8:13 am Post subject: Time's Toll has taken a Toll on my Oil Door |
Still an option, Bill...
[img]cid:ii_jxj5idhb0[/img]
1900 hours, no issues or bird nests.
--Dave
On Thu, Jun 27, 2019 at 3:25 PM Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
| Quote: | Passing throught 1150 hours, it appears that my oil door latches are
Just FYI folks.
plane" Watson
616.58 KB |
7192 Time(s) |
_________________ --Dave
KWVI |
Lew Gallagher
Joined: 04 Jan 2008 Posts: 402 Location: Greenville , SC
Posted: Sun Jun 30, 2019 8:24 am Post subject: Time's Toll has taken a Toll on my Oil Door |
Holy Cowl, now THAT’S an oil door!
Later, – Lew
Sent: Sunday, June 30, 2019 12:12 PM
Subject: Re: Time's Toll has taken a Toll on my Oil Door
[img]cid:E973FF91BE394DECB05FDF99646B37A3(at)LEWDELL[/img]
--Dave
Just FYI folks.
plane" Watson
616.58 KB |
7191 Time(s) |
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
