Ttail
Posted: Sat Jun 15, 2019 10:55 pm Post subject: SS new Air tank weights CJ6A |
Gooday All. I have just replaced my original pneumatic tanks with Doug's new SS Pneumatic tanks. The new tanks are significantly heavier here are the weights.
Old Emerg Cast tank 1.3Kg
New SS Emerg Tank 3.4Kg
Old Cast Main Tank 6.0Kg
New SS Main tank 13.2Kg
So Basically both Old tanks weighed 7.3Kg
New SS tanks weigh 16.6Kg
A diff of 9.3Kg
So significant W and B issue you need to solve. In my case I removed 10Kg Lead Ballast and 1Kg elsewhere.
wlannon(at)shaw.ca Guest
Posted: Sun Jun 16, 2019 10:51 am Post subject: SS new Air tank weights CJ6A |
Just to set the record straight the CJ6 air tanks are not manufactured from
"cast" steel. They are forged from a relatively high tensile carbon steel
probably in the order of AMS 4130 or 4340 and heat treated accordingly. Of
course their primary enemy is moisture and corrosion.
To mitigate the corrosion problem and match that strength with stainless
steel requires a much greater wall thickness.
Walt
jonboede(at)hotmail.com Guest
Posted: Sun Jun 16, 2019 11:47 am Post subject: SS new Air tank weights CJ6A |
In the CJ, heavier tail is better. I have yet to see one that couldn’t stand a few more pounds well aft.
Jon
[quote] On Jun 16, 2019, at 1:57 PM, Walter Lannon <wlannon(at)shaw.ca> wrote:
Just to set the record straight the CJ6 air tanks are not manufactured from "cast" steel. They are forged from a relatively high tensile carbon steel probably in the order of AMS 4130 or 4340 and heat treated accordingly. Of course their primary enemy is moisture and corrosion.
To mitigate the corrosion problem and match that strength with stainless steel requires a much greater wall thickness.
Walt
Ttail
Posted: Mon Jun 17, 2019 5:16 pm Post subject: Re: SS new Air tank weights CJ6A |
In my setup I had a 10Kg ballast bar in the vicinity. I removed that after fitting the new tanks and get 0.7Kg weight reduction over all.
