Which bolt?
jay-dub
PostPosted: Tue May 21, 2019 3:53 pm    Post subject: Which bolt? Reply with quote
Due to the quality of the grass strip at my base, I’ve sheared this bolt on the nose gear. What do I need please? The Parts Manual says HB1-503G1x70x10 but I need that in British English please.
M6x10mm or something else? High tensile presumably...
Thanks.
CJ owner
wlannon(at)shaw.ca
PostPosted: Tue May 21, 2019 7:20 pm    Post subject: Which bolt? Reply with quote
Unless I have missed a photo here the only thing I see missing is a grease
fitting plus one hell of a messy nose gear.
If this is your missing part I would have to assume you do not have a
Chinese (or Russian) grease gun and occasionally use it, otherwise you could
not possibly
mistake this for a bolt.
Walt
AlaskaChang801
PostPosted: Wed May 22, 2019 12:17 am    Post subject: Re: Which bolt? Reply with quote
Yes Walt is correct. That’s a grease nipple that’s missing.
 Filesize:  64.76 KB
 Viewed:  8594 Time(s)
 Filesize:  64.76 KB
jay-dub
PostPosted: Wed May 22, 2019 1:03 am    Post subject: Re: Which bolt? Reply with quote
It seems mine isn’t stock then. This is the other side...
CJ owner
pennington.construction.i
PostPosted: Wed May 22, 2019 1:12 am    Post subject: Which bolt? Reply with quote
That is a stock Chinese grease fitting.
That is what is missing from the other side.
On Wed, May 22, 2019 at 5:08 AM jay-dub <flyjnw(at)gmail.com (flyjnw(at)gmail.com)> wrote:
--> Yak-List message posted by: "jay-dub" <flyjnw(at)gmail.com (flyjnw(at)gmail.com)>
CJ and Yak-52 owner
http://forums.matronics.com/viewtopic.php?p=489334#489334
http://forums.matronics.com//files/28fb271c_dd2d_4e06_b4aa_80495f16c03f_798.jpeg
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
WIKI -
jay-dub
PostPosted: Wed May 22, 2019 1:17 am    Post subject: Re: Which bolt? Reply with quote
Thank you.
CJ owner
jay-dub
PostPosted: Wed May 22, 2019 7:03 am    Post subject: Re: Which bolt? Reply with quote
Thank you.
CJ owner
