yakman285(at)gmail.com Guest
Off2wildblue
Posted: Sun Jun 02, 2019 1:04 pm Post subject: Re: Mag Coils- again |
I just started flying the plane and I have an issue that popped up with my mags. Mag 2 is getting a 200 drop and the 1 is getting between 80-100. The plane ran well on my checkout but on my first day to solo my run up had issues so I taxied back.
My idle fluctuations were from 300-360 with the manifold pressure erratic as well. The only thing I did was that I installed the longer spark plugs that were BRP’s. I wouldn’t think that would matter but I can’t really tell you how it ran before because I swapped them prior to these flights. I am a new owner as you might have guessed.
I was wondering what you think I should check and look for. I just want to take a look at it and see if there’s something that is obviously wrong. Could this issue be related to mine. My new plugs were set at .020” could have been a hair more beuse I only had the disc that went down to .020”.
What are your thoughts?
SAM
Posted: Sun Jun 02, 2019 4:06 pm Post subject: Mag Coils- again |
Sam,
I addressed these issues in a reply to the personal email you sent me.
Dennis
On Sunday, June 2, 2019, 5:06:36 PM EDT, Off2wildblue <Off2wildblue(at)me.com> wrote:
--> Yak-List message posted by: "Off2wildblue" <Off2wildblue(at)me.com (Off2wildblue(at)me.com)>
I was wondering what you think I should check and look for. I just want to take a look at it and see if there’s something that is obviously wrong. Could this issue be related to mine. My new plugs were set at .020� could have been a hair more beuse I only had the disc that went down to .020�.
SAM
http://forums.matronics.com/viewtopic.php?p=489439#489439
http://forums.matronics.comhttp://wiki.matronics.com
http://ww======
richard.goode(at)russiana Guest
Posted: Mon Jun 03, 2019 2:43 am Post subject: Mag Coils- again |
I would be as sure as I can be that this is an absolutely "normal" magneto coil problem, and the only solution is to change the coils.
RICHARD GOODE AEROBATICS
Rhodds Farm, Lyonshall, Hereford, HR5 3LW, UK
Tel: +44 (0)1544 340120 Fax: +44 (0)1544 340129
e-mail: richard.goode(at)russianaeros.com
www.russianaeros.com
WORLD LEADERS IN RUSSIAN SPORTING AIRCRAFT & ENGINES
In partnership with Aerometal Kft, Hungary.
